Need help! No spark
Old Jan 21, 2015 | 12:51 PM
joescvette's Avatar
joescvette
Default Need help! No spark
1978 corvette L82 350 4 speed, turn the key no spark, then turn the key again has spark. Wire to the dizzy is hot. Replaced w/new dizzy still no spark. Pull spark plug no spark. Then sometimes it has spark. Wires tight on starter. trying to get car started, never heard it run. Been parked for over 10 years. Any ideas. thanks
Old Jan 21, 2015 | 01:01 PM
JimLentz's Avatar
JimLentz
Do you have a good ground to the distributor through the engine block?
Old Jan 21, 2015 | 01:22 PM
joescvette's Avatar
joescvette
NOt sure, how do I know?
Old Jan 21, 2015 | 01:53 PM
MelWff's Avatar
MelWff
when you have no spark, you still have 12+ volts at large red wire on distributor?
joescvette's Avatar
joescvette
Could it be the ignition switch, can it tested in the car?
Old Jan 21, 2015 | 02:11 PM
JimLentz's Avatar
JimLentz
Voltmeter leads from battery ground to distributor body should read close to 0 volts.
Old Jan 21, 2015 | 03:02 PM
joescvette's Avatar
joescvette
Also I get no spark when the engine is cranking, and sometimes I do get spark. with key on I have 12+, start cranking I have no spark to the plugs. and sometimes I do. any help let me know. I have to get to a appointment.
Old Jan 21, 2015 | 03:19 PM
MelWff's Avatar
MelWff
this is the circuit diagram, when cranking and no spark do you have 12+ volts at the distributor
http://willcoxcorvette.com/product_i...6ff078cc98305a
Old Jan 21, 2015 | 05:26 PM
Solid LT1's Avatar
Solid LT1
Sounds like a failing ignition switch or fuseable link in the wiring harness.
Old Jan 21, 2015 | 05:32 PM
lowes-yellow77's Avatar
lowes-yellow77
Default eliminating parts
Well you have eliminated the dist if you put in a known good one a slight trick to try
Get a test light with long enough leads you can see it if it lights up while you're cranking. Prod or poke the power wire going to the dist and crank.
Keep tracing back along the wire amd see where it is losing the 12v until you get a steady light.
Im not saying it'll work but ive used this system before and found the break in connections
Old Jan 21, 2015 | 08:38 PM
joescvette's Avatar
joescvette
Thanks for all the help. I will replace the ignition switch this weekend, and go from there.
Old Mar 4, 2015 | 08:51 PM
tokim's Avatar
tokim
Update?
Old Mar 5, 2015 | 05:29 PM
gungatim's Avatar
gungatim
before you start firing the parts cannon at it, or rather firing another round, test the wiring. 78 should be HEI. before replacing distributr test the module, cap, rotor, do you have 12v at the power wire? you do know you don't get spark when the key is on, the engine has to be cranking. if the power to the dist. is what is intermittantly missing, trace it back, after ruling out bad connector. what happens if you hot wire it? run 12v to the dist from batt and crank the engine, does it have spark then?
Old Mar 5, 2015 | 05:35 PM
qwank's Avatar
qwank
Don't you mean 0 OHMS?
To Need help! No spark
