Cable????
Old Jan 28, 2015 | 04:36 PM
Tbone4432's Avatar
Tbone4432
Default Cable????
My friend and I pulled the motor out of my '77. We thought we had everything disconnected...we thought wrong. As we pulled the motor out, a ground? cable was severed. It was connected to the motor and affront suspension piece. Is this a ground cable? Where can I find a new one? or can I make a new one? Thanks for al your help.
Todd
Old Jan 28, 2015 | 04:48 PM
mikem350's Avatar
mikem350
Its a ground and is important to connect the frame to the engine block. It completes the circuit from the neg battery cable. Fix it or buy a 2 gauge jumper.
Try a vette catalog supplier if its easier for you!
Old Jan 28, 2015 | 04:57 PM
speedreed8's Avatar
speedreed8
http://www.zip-corvette.com/catalog/...-ground-cable/
Old Jan 28, 2015 | 05:04 PM
The13Bats's Avatar
The13Bats
If you are not purist stock I suggest getting or making a larger gauge cable...
When my 69 comes back I plan to run both + and ground cables new and larger....
To Cable????
