1982 CE restoration help!
Congrats on the CE.
You can buy SEM liquid dyes at most professional auto body paint supply stores. They can mix it to interior color codes or to match a part you bring in. If you don't have spray equipment, also buy a Pre-Val bottle sprayer ($10) and 2-3 spare gas cartridges. They work GREAT with the liquid SEM dye.
On all surfaces that you want to re-color, you MUST clean them COMPLETELY of all dirt/dust/oil/'protectants'
with cleaner or detergent; then you must remove all traces of cleaner and/or detergent with lots of fresh water; finally allow to dry completely.If you have multi-color seats, you need to mask off areas, then dye each color separately and allow to dry completely.
It's much better to completely remove the seats from the car (sounds obvious, but I needed to say it). Better access and no need to mask other areas of the interior.
YOU CAN DO IT! And, when done, the interior will look like new.
