Adding A/C - how bad does it screw up "original"?
Old Feb 9, 2015 | 07:08 PM
Cajun_LS3's Avatar
Cajun_LS3
Default Adding A/C - how bad does it screw up "original"?
Still looking for the right chrome bumper C3 for me. I keep passing up cars without A/C because in TX, it's very important to me to have A/C. I want to get a car that is mostly original, and keep it as original as possible. I'm not planning to get it judged or anything, but I don't want to reduce its value by adding A/C to a car that did not originally come with it. I'd like to hear some opinions on if this is something that I should really be concerned with or not.
Old Feb 9, 2015 | 07:38 PM
Bad Bird's Avatar
Bad Bird
My car is a quite original car with its "born-with engine" (L36, 4 speed car). With that said, I intend to add a Vintage Air kit to the car to make it something I can go on long drives with. It looks like it's not that hard to go back to original with the Vintage Air if I change my mind.
Old Feb 9, 2015 | 08:17 PM
74modified's Avatar
74modified
You could add A/C, then take it back off later if you wanted. You just wouldn't want to cut anything up. Save any parts you take off.
To me, a "driver" - one you can get in and enjoy would be worth more with the A/C.
Old Feb 9, 2015 | 08:18 PM
The13Bats's Avatar
The13Bats
I would guess in the world of ncrs it would take away judging points,
But it that isnt your bag make your car 100% more fun and comfortable to drive and add AC plan to when I get the toad pelts saved but I modify my car so I dont count as far as original goes....
Old Feb 9, 2015 | 09:38 PM
loquinho's Avatar
loquinho
Think of it this way - if you find a chrome bumper car that's pretty much what you're looking for, and the owner says, "Well, it's pretty much all original, but I added a Vintage Air kit since I live in Texas and wanted to enjoy it." Would that diminish the value of the car to you since it's aftermarket, or would it increase the value since you can enjoy it in the summer? If the answer is the second, you can bet there's plenty of other owners out there that feel the same way when you go to sell it.
One of the things I love about these cars is that they're old enough for there to be a strong NCRS following, but common enough and popular enough that there's always a buyer for what you have. Of course, keeping your modifications removable is always a plus!
Old Feb 10, 2015 | 12:10 AM
68/70Vette's Avatar
68/70Vette
Buy that nice C3 without air. Then purchase a Vintage Air conditioner kit. It fits very well and is far more efficient than the factory unit. I mounts under the passenger's side of the dash...doesn't take up engine room. Buy a repro air conditioned/heater control unit for the console...$150? nice repro unit. With this unit, the interior will look absolutely like a stock C3 with AC.
I've installed a Vintage on my 70 BB car since it will give me a lot more engine room for headers, etc. The car had an original factory AC unit..removed it.
Old Feb 10, 2015 | 05:32 AM
7T1vette's Avatar
7T1vette
If the car you purchase is not some pristine, 'special', hard to find C3 in perfect condition, you won't be hurting the value of it by installing A/C. You may not be ADDING value to it, but it might be more saleable in the future, if you decide to sell it.
Will it be totally "original"? No. Do you care? No. Will others care?
Who cares???
Old Feb 10, 2015 | 08:42 AM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
You could buy almost everything needed to make the conversion "look" stock. This will not hurt the value of your car at all. Everything is bolt on.
Old Feb 10, 2015 | 09:34 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Take your time.......There are plenty of AC cars out there and the selling season is just about here!
Old Feb 10, 2015 | 05:40 PM
cb.bums's Avatar
cb.bums
I have a 75 non-air car. I have a complete air system, but was told the front end needs to come off to install it. true or not, the vintage air system is how I'm going to go.
Old Feb 10, 2015 | 10:59 PM
BeansWorld's Avatar
BeansWorld
cb,
The hood will have to be removed. I doubt the 75 system differs from the 70 system that much, you're installing the condensor and drier in front of the radiator, the rest is easily accessible.
The firewall does require a permanent mod - a semi-circular cut to accept the hoses from the evaporator that is installed under the passenger side dash. You'll need to cut two holes through the passenger side radiator mount to run lines from the drier/condensor to the compressor/evaporator.
When I saw mine for sale, I knew it was the one. But I REALLY wanted AC. So I installed Vintage Air and it's been great. Use the factory AC bezel rather than the cheap plastic piece provided in the kit.
Regards,
Eugene
Old Feb 11, 2015 | 07:45 PM
SWO vette's Avatar
SWO vette
Go for it. I used to worry about numbers and such but now not so much. I just want to drive them and enjoy them. Now if was a real rare car, a one of 10 or something like,that I might not. I guess I am getting more mellow as I age now. It just not that important anymore to me. But, I won't do anything that can't be reversed. After all we don't own them- they own us and we are just their care takers.
Old Feb 11, 2015 | 09:44 PM
rcread's Avatar
rcread
Unless you are buying a ZR1 or LS5, I wouldn't worry about it. Our C3s will never be grade A collector cars worth the kind of money similar year 911s are fetching. The value you get from keeping cool will outweigh the minuscule decrease in value.
Old Feb 12, 2015 | 11:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you want factory air, buy a car with factory air.
To Adding A/C - how bad does it screw up "original"?
