Sparty was a potential fireball
Old Feb 10, 2015 | 05:58 PM
Gordonm's Avatar
Gordonm
Default Sparty was a potential fireball
I am about done working on David's 71 as most of you know it as Sparty. I asked if there was anything else I should check on the car. David responds with yes there is some residue on the muffler which looks like black paint dribbled on the muffler and some fuel stains on the tank. With everything being new, fuel lines, tank, and vent I thought no way was it leaking. I looked and sure enough it looked like a fuel leak. All lines look good tank and vent look good, the nipples are all good. I report back to David and he says let's change the vent anyway, I have a new one here. I agree and it arrives today. I pull the old one out and sure enough I seal off one tube and blow in the other and it is leaking at the seam
Where the screwdriver tip is the case is split. Now I don't know if it was defective or got cracked on the original install or whatever but with a full tank of gas this could have poured fuel onto the muffler. I checked the new one and it did not leak. So on it went. Bugger of a thing to get on with no room to work but it's in there and should not leak now. I guess now I would check every valve before installing. This could have been a real bad fire had it leaked raw fuel on a hot muffler.
Old Feb 10, 2015 | 06:34 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I know I said it a few times already Gordon but thank you, thank you, and thank you. The aftermarket parts quality scares me and this is a good example of why. Now I'll clean up that muffler when Sparty comes home.
Best regards,
David
Old Feb 10, 2015 | 11:17 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
WHEW! GOOD CATCH!
You just reminded me that I forgot to buy a fire extinguisher today!
Old Feb 11, 2015 | 07:13 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Fire Extinguisher
Good point Doorgunner, good point.
I don't have one in Sparty, but I will.
David
Old Feb 11, 2015 | 07:52 AM
tokim's Avatar
tokim
Nice detective work GordonM.
I'm installing a new tank in my '72, when transferring the "fuel separator rollover shut off valve" (pictured), I noticed that it rattles. Should it?
I'm thinking this is correct, as It must be a one way check valve.
Old Feb 11, 2015 | 04:06 PM
Gordonm's Avatar
Gordonm
Yes that is correct. It does tattle. Both the bad one and the new one rattled.
Old Feb 11, 2015 | 04:10 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I strongly suggest that you and all that install these do a form of water pressure test to make sure it does not leak. Cracked housing was the issue for this one. Just a thought.
Best regards,
David
Old Feb 11, 2015 | 06:39 PM
tokim's Avatar
tokim
Thanks Gordonm and AllC34Me
Old Feb 11, 2015 | 07:40 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Best regards,
David
The rattle in these units is a simple ball float (think ping pong ball) that prevents raw fuel from running out the tank (think full tank + hard turn) into the evap hose. I would not pressure test the unit too rigorously - the case will rupture at the seam. It's not designed to hold much more pressure above the vapor pressure from the tank.
Old Feb 11, 2015 | 09:43 PM
Gordonm's Avatar
Gordonm
My pressure test was to put my finger over one of the port and blow Into it with my mouth. I know I cannot generate much pressure by blowing Into it..
Old Feb 11, 2015 | 10:09 PM
Hammerhead Fred
That's my "go to" pressure test too.
Old Feb 11, 2015 | 10:16 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Nice catch. Even though my entire fuel system is new, every time I change my oil I give brakes and fuel a peek looking for leaks.
Old Feb 12, 2015 | 03:26 PM
dembo's Avatar
dembo
That picture looks familiar!
Took me a while to find the fuel smell I all of a sudden had. Exactly the same issue as yours and it was new ... There also was a crack near the base of the nipple
Nick
Old Feb 12, 2015 | 08:28 PM
loup68's Avatar
loup68
Army
Gasoline will eat almost anything. Lou.
Old Feb 12, 2015 | 09:26 PM
Gordonm's Avatar
Gordonm
It should not be a problem with this as these were designed to have gas on them. This valve was brand new and maybe had gas on it once. It was only a few months old. I know some original ones still working after 40+ years. I think it is crappy workmanship more than anything.
Old Feb 14, 2015 | 05:34 PM
hotrodnick's Avatar
hotrodnick
Originally Posted by doorgunner
WHEW! GOOD CATCH!
Bought mine last summer. Made a BUBBA mount wrapped a bungee with a ball on it around the extinguisher and fastened it to the finger lift on the battery cover. Rode there and never moved
To Sparty was a potential fireball
