just curious
Old Feb 18, 2015 | 08:02 PM
Tripower delight's Avatar
Tripower delight
Default just curious
I have a 69corvette non matching # car, I dont have the original engine
but I do have the original tranny. breaking down the # the trans was made march 20th 1969,so with that imformation from the trans whats should the numbers be on the engine to make it a matching # car.
Old Feb 18, 2015 | 08:11 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie answer.........Decode your VIN number. The engine should be dated days or weeks before the car received the VIN.
Old Feb 19, 2015 | 08:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
After March 20, 1969. Your tranny would have been assembled, shipped to St. Louis, and stockpiled before your car would have been assembled. I agree with Doorgunner; your VIN will narrow the production date. What's the time built code on the trim tag?
Old Feb 19, 2015 | 08:22 AM
Revi's Avatar
Revi
Just an FYI on a couple of engine build dates. Others will vary.
1970 VIN 9516 - Engine 03/25/70, Car 05/18/70
1970 VIN 9590 - Engine 03/23/70, Car 05/18/70
Old Feb 19, 2015 | 08:34 AM
Alan 71's Avatar
Alan 71
Hi Td,
Carrying on Revi's thought.
On some cars the engine was cast and assembled really quite close to the car's assembly date.
Engine block cast Dec. 31, 1970
Engine assembled Jan. 7, 1971
Trim Tag date Jan. 14, 1971
All sorts of things affected this timing so this might just be an example of things running very normally and smoothly.
If you were REALLY serious about knowing about your engine's stamp you'd begin searching for cars built about the same time period and see what those engine's casting and assembly dates look like.
It's kind of a fun puzzle but also can be frustrating.
There are people who have been running surveys like this both formally and informally for YEARS!
Regards,
Alan
Old Feb 19, 2015 | 07:06 PM
Tripower delight
Originally Posted by Alan 71
Hi Td,
Regards,
Alan
yes it is fun and quite frustrating, and very expensive,my trim plate reads H25 so the trans and the trim plate are a week apart, I agree, to really lock it in would be to find a car with a serial #that is close to mine.
Old Feb 21, 2015 | 08:55 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Tripower delight
...my trim plate reads H25 so the trans and the trim plate are a week apart...
That's a bit close, but do-able.
Old Feb 21, 2015 | 08:02 PM
Tripower delight
I've owed this car now 17yrs now never gave a dam about matching #s, I quess all these yrs hearing about matching #s has worn me down a bit,I doubt I would go that route if I found an engine because of the expense.
Although there is a guy selling a block for 500.00 bucks but it was cast the wrong year for my car, it just good to know in case I do come across something one day,thats why I posted the thread. T hanks to all that posted to provide the information that I needed.
Old Feb 23, 2015 | 08:45 AM
Revi's Avatar
Revi
If you're interested in "numbers and originality" you should purchase the 1968-69 Technical Information Manual & Judging Guide, it will explain alot. You don't need to be a member to purchase.
https://www.ncrs.org/shop/index.php?...roducts_id=217
To just curious
