What is this?
Old Feb 25, 2015 | 11:03 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Default What is this?
Last night, I was organizing parts for cleaning, plating, rebuilding, etc. and came across this...
I'm a restorer so I find things like this really cool, but originally, these broadcast labels simply made it easier for the plant to track inventory and for the workers to install on the line. This particular code is almost always present, but due to its location, is rarely seen and may not hold up well.
Now the guys who have taken a Corvette or two apart will probably know what and where this came from, but I'm guessing that most will not. The code itself should be a give away for some people too. In any case, I'll leave this up for a few hours for folks to look at and discuss, then post a some wider angle photos that show things a bit more clearly.
Have fun!
Regards,
Stan Falenski
Old Feb 25, 2015 | 11:10 AM
TNT's Avatar
TNT
The rear end assy code tag!! It glues itself to the rear diff cross member or stays on the differential . You have to remove the assy and separate the two to see it.
Thad
Old Feb 25, 2015 | 02:19 PM
Alan 71's Avatar
Alan 71
Hi,
I'm thinking 3 letters make it appropriate for a late 1969 and 1970 model car that was destined to get pretty poor gas mileage?
Regards,
Alan
Old Feb 25, 2015 | 03:47 PM
Rowdy Rat's Avatar
Rowdy Rat
Thad
Doesn't surprise me that you knew what this was!
Your description is right on the money. The only way to see it is to remove the differential from the cross member. The tag often sticks to both parts so you end up with what you have here... Part of it on the diff, the other on the cross member. This one actually held up pretty well as it came off of a 37,000 mile car.
Originally Posted by Alan 71
Hi,
Regards,
Alan
And you would be correct too Alan!
The broadcast code is for a 1970 Corvette with a 4.11 to 1 ratio rear.
As you can see, I still need a little work on the "C," but it's really close. Considering you're never going to see it once the differential is installed...
In any case, I thought it was pretty cool... Hopefully a few other folks did too.
Regards,
Stan
Old Feb 25, 2015 | 04:13 PM
Alan 71's Avatar
Alan 71
Hi Stan,
I think the font looks good.
Effort put into restoring parts and areas that won't be seen when the car is assembled will be rewarded in Heaven.
Regards,
Alan
Old Feb 25, 2015 | 04:38 PM
hunt4cleanair's Avatar
hunt4cleanair
Missed the earlier quiz time but retrieved code from my 78 a few years back. Includes a date code...I think.
Old Feb 25, 2015 | 11:36 PM
Rowdy Rat's Avatar
Rowdy Rat
Very cool Tom!
A bit different than the earlier version... But the tag is still somewhat similar too.
Regards,
Stan
Old Feb 26, 2015 | 04:15 AM
hunt4cleanair
Thanks Stan
I was a little tepid about posting since it was off a 3:08 two-pedal car compared to your 4:11 gear Pretty good size tag
Here's another look at it:
Old Feb 26, 2015 | 04:17 PM
62corvette's Avatar
62corvette
Stan,
If you get ahold of the right people, you could possibly get that included in the NCRS 70-72 JG revision.
Old Feb 26, 2015 | 05:18 PM
Alan 71's Avatar
Alan 71
Hi,
I can see the instructions now:
"Please remove the air cleaner and distributor shield, and also drop the rear differential".
Regards,
Alan
Old Feb 26, 2015 | 07:46 PM
Rowdy Rat's Avatar
Rowdy Rat
Originally Posted by 62corvette
Stan,
LOL!
"I know this guy...."
Regards,
Stan
To What is this?
