Severity of Windshield Frame Rust?
I could use some help gauging the severity of this rust. The inspector said he thought the pictures looked worse than it really was. What's rust, what's sealant and what is old, warped trim? By the way, the car is out of state, so I'm a plane ride away from being able to put my eyes on it. I will, before the transaction is done, but need to make a decision wether it's even worth the plane ride.
I've seen worse, and as far as repairs go this is pretty easy. I'd be sure to ask how everything is below because water runs downhill.
Post some more pictures when you get the chance.
Best of luck!
r
You can see in the last picture no signs of damage. I can show you the finished pictures if you are interested.
Windshield frame can be fixed, but it takes some work.
I agree with all the things people posted….. there's no reason to not remove the interior trim to get a better look at the windshield header. There's no reason for you to spend your money with this uncertainty.
There has to be a lot of rust formation to have forced the trim pieces out of alignment as far as the ones shown in your pictures. They didn't 'warp' because of 'time'.
Also, that's a non tinted windshield which MAY mean it's been replaced and thus who knows what might be going on under there. I'd want to know about that windshield too.
BE VERY CAREFUL!
Regards,
Alan
One more thing… in your post you say he said "he thought the pictures looked worse than it really was ".
Did this person look at the car or at the pictures?
BE VERY CAREFUL!
Regards,
Alan
Been there. In my case I had the header and both corners replaced with parts from a donor. It wasn't a huge deal though beyond what I could handle myself. Had to have a shop do the repair. You can get a pretty good idea of where it stands if you remove the interior trim, pillar and header. At least you'd have an idea of what you're in for.
The problem is much worse if you find rust at the bottom of the windshield frame, underneath the surround panel.
My 2 cents and experience; I pulled windshields out of my 72 and 68 in both cases to go ahead and fix some visible rust in one place only for each and discovered 3 & 4 fair sized holes in each. I was able to cut repair patches and my buddy welded them in so all ends well. So, I have come to the conclusion that most all C3's have some windshield frame rust, maybe just not visible yet, and yes, once you take the windshield out, I am certain you will find the problem to be bigger than seen now. So, all is doable with time and money, I would just factor this in your offer if you proceed. And, if anybody can tell me how to get a windshield out without cracking it, you are my hero, so figure in a new windshield in the equation too. Hope this helps and GLWB. Also, if the rest of the C3 looks great, this would not be a show stopper for me, just a negotiating point. And, if you really like the rest of the Corvette, a plane ticket will no doubt be the best investment you make on this one, worst case, you get a weekend vacation to hopefully a nice destination!
BE VERY CAREFUL!
Regards,
Alan
I'm really struggling with this one. Overall good car and good price, just the unforeseen with this particular item. The inspector went through this car pretty well, spending around 4 hours on the inspection, gave me a detailed verbal report and is mailing the written report to me with additional photos. I'm leaning towards known devils are better than unknown ones. I need to just figure out what's going on under that trim and the extent.
My question is...Should an inspection always include taking the inside windshield trim off as well as the kick panels and access panels in the back to inspect the body mounts....? I understand the owner should be made aware of this before hand as well as the inspector and if either refuses just keep looking an appropriate owner/inspector....?
Brian
Taking a car apart that not yours is NOT going to sit well with an owner especially if he doesn't want you to know what's under there.
If I saw a car that didn't give me any reason to wonder I guess I could forgo the look… but if I were suspicious I'd back away unless I was comfortable in buying a car that could well need birdcage repair.
There's a reason the car in C's picture looks the way it does. The original soft trim has a metal form it's made on. That form can rust. We could be seeing trim rust or windshield frame rust. I'd want to know which while the money was still in my pocket.
Regards,
Alan
Regards,
Alan
my 2 cents is that you will not know what is going on under the trim until you take the windshield out or at least that is my experience. Also, rust expands 7 or 8 times the thickness from original steel. Good luck with the search.
some people swear that all they did was replace the windshield frame and that the birdcage was fine.. I would not believe them.
I also expect that your seller will not let you disassemble the panels of the car to look for rust.
I sent you a PM. Did you see it?
It does look like water has been laying IN the soft trim and rusted it.
What concerns me is how lumpy the birdcage itself is AND the fact that it's black.
This MAY well mean that the header is rusty and has been painted over to try to stop or conceal the rust.
I'm not concerned about the trim at all, but rather the header.
The pictures I'll post are sort of ideal but does show what the birdcage, sealer, glass, and soft trim can look like.
Perhaps you can understand that what's showing in your pictures is concerning.
Regards,
Alan
This is what that area of the header looks like with everything but the corner casting removed.
This the a-pillar but illustrates how the various material should look and fit. This is a restored car but note how smooth the birdcage a-pillar is.
Where I DID find rust was on the header, coming from the inside out. The shop which worked on it thought it was fine when they first pulled the windshield but found the metal was thin when they hit it with a body hammer. A few holes in the header, some thin spots on the top corners.
I say a rusted header is definitely a red flag but isn't necessarily indication of wide spread windshield frame rust. More inspection is needed. Can't say for sure without taking the windshield out, removing trim, and digging the factory caulk out from behind the surround panel.
Unfortunately I doubt a seller would allow anyone to take the car that far apart. Best a buyer may get is a look on the inside IF the owner is willing to remove the trim for inspection.
There will be some risk. If the buyer wants to be safe, hold out for one with NO rust.
Body guy sent a photo and I choked on my soda! Drove over and we took a fine wire wheel to it and it cleaned right up, no holes. Whew! According to the glass man, the wrong sealer was used and that attacked the metal, causing this rust, everything else (including the birdcage at the frame) is OK.
