I have a 71 vette 350 auto had engine rebuilt machine shop in Sayreville nj. This was done in 07 .car shook the rebuilder said it was carb .i had carb rebuilt .still ran crappy.machine shop still said it was carb .i took carb back 2 more times.no good.car sat in garage .finnaly did compression test.valves were bad had second valve job done.new over size valves and new springs put heads on. Started car ran same.bought new carb from summit racing.put it on it ran same .put new wires cap roter .points have protronics.still ran same.very hard to keep running.and engine smells like gas Carbon when I start it in garage any body have an idea.thanks joe.vaccume is between 8 and 12
Reason: More info.
did you do a compression test after reinstalling the heads?
what carburetor did you buy from Summit?
what is your initial timing set for? what is your total mechanical advance set for?
did you check for a vacuum leak around intake manifold to head and carburetor to head?
what camshaft do you have?
I have a 71 vette 350 auto had engine rebuilt machine shop in Sayreville nj. This was done in 07 .car shook the rebuilder said it was carb .i had carb rebuilt .still ran crappy.machine shop still said it was carb .i took carb back 2 more times.no good.car sat in garage .finnaly did compression test.valves were bad had second valve job done.new over size valves and new springs put heads on. Started car ran same.bought new carb from summit racing.put it on it ran same .put new wires cap roter .points have protronics.still ran same.very hard to keep running.and engine smells like gas Carbon when I start it in garage any body have an idea.thenks joe
Hi Joe
I am far from being an expert, but from all the work you have done and nothing has helped. I was wondering if the builder got the cam timing way off? Hope someone can help you with the problem.
Larry
I bought a jet carb quadrajet 35001 new.the timing was set for 4 degrees befor top dead center.but wants to run way edvanced.i did check for leaks. I even changed intake from the original to edelbrock .the engine is hard to keep running shaks till it stalls.cant put in gear .stalls out.thanks for your input joe
4* is not nearly enough timing. Set it to 14* to 18* of initial. See what happens then.
There are no new Q-jets. As stated by Lars, if you bought a commercially rebuilt Q-jet then it is likely junk in it's present condition. It will need to be built by someone like Lars or you need a different carb.
