Did anyone replace the a arm dust shields on a 71. I bought the rubber shields with the anchors and wondering if it was easy and if there is anything I should anticipate? thanks
You just push the pins (anchors) through the shield into the holes in the inner fender. Very easy installation. The other end gets tucked into the opening in the A-arm.
Ok cool, I did get the pins. I just didn't want to screw it up. Thank you
It looks like you already finished the job. This was one of the first things I did to clean up my engine bay on my 72. Putting the new dust shields in place helps clean up that area, was cheap to do, and easy to perform.
