Engine Pad Stamps
John Hinkley, (John Z), posted some interesting info on the DB.
"Flint and Tonawanda BOTH produced about 5500 engines per day…300 engines per hour".
Even if 99% of the engines leaving those plants each day had 'perfect' assembly code stamps, 55 didn't.
If you multiply that times the number of days per year the plants worked it's no wonder we see many odd stamps.
Regards,
Alan
I hope this isn't a trick question because I'm not good at this.
V….Flint
06….June
21….21st
CLF… 1977, 350 ci, automatic, L-82, California, Corvette
How does that sound?
I like the surface on the pad.
Regards,
Alan
You have a 77 automatic, L-82 with California emission equipment.
"V" is the engine assembly plant, at Flint Michigan. "0621" is the date the engine was assembled, June 21, 1977. "CLF" is the engine suffix code, or identifier, which indicates a 77 L-82 attached to an automatic trans, and equipped with California emission equipment.
To take it further, your VIN derivative breaks down as follows.
"1" is Chevrolet Motor Division. "7" is the 1977 model year. "S" is the St. Louis assembly plant. "4" is just a GM control number and 41449 indicates that you have the 41,449th 77 Corvette built. The birthday calculator shows 41449 to have been built on aproximately July 2, 1977.
Here's another picture from John's collection!!
The infamous 'gang' holder and the box with the stamps in it.
I believe this is from the mid-years but I'm thinking the holder didn't change much for our cars.
I think our cars required 1 more digit starting in 70-71?
Notice the glove and hammer in the picture too.
Regards,
Alan
However, if you factor exactly how many of those 5500 motors per day went into Corvettes, the percentage of Corvette oddities would be quite small. One percent might be high?
Had to be hotter than hell working there!
Yes, but the only engine stamps they screwed up were those headed for Corvettes, and then only LT-!, 427, and 454 engines.
I don't know if I've ever seen an odd pad on a base motor? You?
Regards,
Alan
I've been wondering where you've been? Hopefully either too busy or too far away!
Regards,
Alan
Both busy and far away!
I've always been relieved that the pad on my '75 is nice looking.
I do remember viewing this car, which will clearly raise some eyebrows:
Now trim tags - I feel that is a topic that in the large, general circle does not receive enough scrutiny as the engine pad does. Many people coming to this forum asking about their "matching numbers" and referring to the previous stamp pad, but may not even know of the trim tag existence.
You mention the assembly stamp side of the pad, it just gets even more compounded with the man whacking that gang stamp on the St. Louis/BG assembly line! In my second picture above, it appears the Tonawanda guy did a fine job, then the St. Louis guy came along and ruined nice, pretty pad stamp.
I wish I would of thought of the 1BadMofo stamp, that is pretty cool.
I need to come up with something clever on my pad. Maybe 7t2 has started a trend
If one reads about 'heavy repair' one can pretty well understand how some pads ended up looking like they do.
It sounds like repairing engines that ended up in heavy repair without ever leaving the engine plants, or those that came back from St.Louis, was pretty low on the list of things to do.
Certainly getting a stamp back on the engine or changing the original stamp wasn't given much thought or effort.
Regards,
Alan
mike...
