Carb identification
Old Mar 15, 2015 | 12:58 PM
brennano1's Avatar
brennano1
Default Carb identification
Can anyone tell me about this carb?
Old Mar 15, 2015 | 02:22 PM
Brian79's Avatar
Brian79
Default Carb Identification
A little more info may get you more responses, but google it and it appears to be a Holly used on 1970 Camaros' and some Corvettes
Old Mar 15, 2015 | 02:49 PM
donaldb1's Avatar
donaldb1
[QUOTE=brennano1;1589187226]Can anyone tell me about this carb?
1970 427, 454 engine, Corvette- 360,370,375, 450 H.P.
Old Mar 15, 2015 | 02:54 PM
brennano1's Avatar
brennano1
I googled it but the responces were inconsistent.
Additional markings:
34r-2177b
3
6333
4555
6t-3651
Old Mar 15, 2015 | 03:01 PM
donaldb1's Avatar
donaldb1
The carburetor is a Holley.
The 3972121 number are key number that tie it to real cars. Google only knows what it is told, I matched the number in the book.
Old Mar 15, 2015 | 06:58 PM
Brian79's Avatar
Brian79
Default Carb ID
googled this # came back Holly carb. 1970 Camaro also LT1 Corvette
Old Mar 15, 2015 | 10:51 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I would surmise it is a service replacement by the fact that the format of the date code is a julian date instead of a year/month/week format that is typical of the early '70s Holleys.
Old Mar 16, 2015 | 02:48 PM
joewill's Avatar
joewill
according to the corvette black book, that is a corvette LT1 1970 4-speed holley carb.. not sure it is also a camaro z/28 LT1 carb as I don't have that reference material. I would logically guess that might be true too.
I show it as a 780 CFM vacuum secondary
new carbs are available with some of these numbers that are not 1970 built carbs so do your homework on what all the other stampings may mean.
Old Mar 16, 2015 | 10:52 PM
bop's Avatar
bop
Default holly carb
Call holly and give them the numbers and they can tell you what it came on. I did this before I had my LT1 carb rebuilt. I did not want to spend the money to rebuild a non LT1 carb.
Old Mar 17, 2015 | 07:42 AM
toylman's Avatar
toylman
Lemans Pete is correct. It's a 1970 LT1 service replacement. As he states, originals had 3 date characters; year, month and week. One of your other numbers, 6333, is a metering block. On the original, the other one would be 4519.
34r-2177b
3
6333
4555
6t-3651
To Carb identification
