Differential numbers?
Old Mar 15, 2015 | 09:55 PM
mcltcb's Avatar
mcltcb
Default Differential numbers?
My 1975 diff has this on the bottom -LR W 281 E1. Why is there no date code?
Old Mar 15, 2015 | 10:24 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
The casting date is on the side of the housing, drivers side right above the leaf spring.
Old Mar 15, 2015 | 10:30 PM
Revi's Avatar
Revi
LR (3.36), Warren Axle Plant, Julian Date 281, Eaton Positraction, 1st shift
Old Mar 15, 2015 | 10:44 PM
LeMans Pete
Revi does describe this correctly, as you can see it is built on the 281st day of the year. since LR was used for at least '75-'77 (and possibly more) you will need to verify the casting date on the side of the housing as I describe to identify the correct year.
Old Mar 16, 2015 | 09:06 PM
mcltcb's Avatar
mcltcb
Thanks. I'll take a look there.
To Differential numbers?
