Brake bleeding issues...ugh! Help?!
So, I purchased 6 speed bleeders. Last evening, I installed all of the bleeders, and then proceeded to the left rear of the car to begin. No problems, got all of the air out, same with the left outer rear. Moved to the right inner rear, no issues, right outer rear, no issues. Got to the front and realized there was brake fluid all over the floor. Apparently the bleeder on the left front was not seating properly, as even when tightened down, it was spewing fluid. Just great! And of course the front half of the master cylinder was drained down, so now I had even more air in the system. I topped of the master cylinder, and started again at the left rear. Bled both halves of the caliper with no problem. Got to the right rear, and no matter how many times I tried, I kept getting a steady stream of bubbles from the outer bleeder. I was constantly checking the MC to ensure that it wasn't getting too low. I even went back to the original bleeder, and had a partner assist me again. So at this point I am thinking that I have a bad caliper, because air appears to be getting sucked back in on the return pedal movement.
I moved to the front left (the one that initially had the speed bleeder issue), and I had the same problem. Even using the original bleeder. Steady stream of air. So now my brakes are even worse than when I started, and my $40 worth of speed bleeders was a complete waste. But even with a pressure bleeder, I don't think I am going to be better off.
Does this sound like a bad caliper(s) issue? Possibly a bad MC? Not really sure where to start, but looking for some expert opinions and advice. I am thinking about starting with a new master cylinder, as they are pretty inexpensive. Bench bleed that, and then start over with the bleeding process. Any other suggestions would be greatly appreciated!!!
Get a Motive Bleeder. Add a few cans of fluid and pressurize it. Make sure it holds so you know you have no leaks. Do a walk round and check every connection.
If all is good start in the rear and crack it. While it bleeds hit the caliper with a rubber mallet. If you are getting clean fluid close it off.
Do each caliper of course and you should have a really good bleed. Break the seal on the MC and dump the unused fluid.
I have never used one, so that makes sense. So, if I pressure bleed and have no air bubbles, no leaks, and then STILL have issues, what next? Master cylinder?
I bought all new bleeder screws and found tiny bits of "trash" using a bright light looking into the bleeder holes/cleaned-flushed the trash out of all the calipers and installed new seals and the new bleeders.
Then I removed the master cylinder/honed the bore and installed new seals/BENCHB-LED the master cylinder/re-installed it.
I did the two-person bleeding method.....it took an hour to bleed all the bleeders, but the pedal has been firm for a year now.
Next time I'll buy a Motive bleeder
then re-install it and start fresh........trust me/been there for 3 days!
You have been given alot of good information here. For me I use the gravity method, with a rubber mallet to tap on the calipers to break any air bubbles lose. Another thing I have read here on the forum is to put some grease around the bleeder screws to keep air from getting into the system. Because some of the screws are a little lose where they screw in to the calipers. I have always had good luck with this method, and had a good pedal.
Good luck, hope you find the problem and fix it.
Larry
First do you have the original calipers on the car? If you do, then ultimately your calipers will likely leak as the caliper seals are known to fail over time.
You can purchase rebuilt calipers from supporting vendors that have updated seals and sleeves that will solve the problem.
I went with Wilwood calipers as I wanted better overall technology and weight savings. I also purchased a new Wilwood Master Cylinder as I didn't want to deal with rebuilding the original.
Ultimately, I still purchased a pressure bleeder because even with brand new Wilwood components I still could not bleed the system successfully by using manual processes.
Hope that info. helps you to save some money,grief, and time.
With the engine off, if the pedal is pumped 4 times, it will stay about 1 1/2"-2" off the floor, but if I release it and then push it again, it slowly goes to the floor. With the engine running and the booster assisting, the pedal always goes to the floor. So I get under the hood and look, and there is some brake fluid under the MC on the steering linkage and frame rail. It appears as though there is still some leakage at the rear of the cylinder where it mounts to the booster. So I assume I have ANOTHER bad Master Cylinder? I am at the end of the rope with what should be so simple, and something I have done many times in the past with many vehicles. Feedback and suggestion would be appreciated!!
Thanks everyone!
Check the booster to see if excess brake fluid is dripping out of it which could make you think the new master cylinder is leaking.
Vette brakes are monsters to bleed completely....I feel for ya"!
