Lighted Emblems ( HOW TO(
Old Apr 5, 2015 | 04:32 PM
Danny.reamer's Avatar
Danny.reamer
Default Lighted Emblems ( HOW TO(
First you want to go to lowes or Home Depot and gat a piece of LEXAN not plexi glass I repeat not plexi glass. And dremel set and rotozip cutter
Next you will need to cut a strip of LEXAN about a half inch bigger then whatever emblem you are doing
After that if you are doing the front emblem you will take a tourch and heat it up to make it couture to the emblem and it doesn't take much heat at all to bend it
Next I drilled holes in LEXAN with rotozip so that the emblems would sit down flat and I traced it out with a pin
After that I took the rotozip and cut the lexan out a little bigger then traced lines
Than you can take the grinding wheel that came in the dremel pack and grind it down just to the lines so that it fits flush behind the emblem
Now you will take your etching bit that came in the dremel set and etch out a channel on the inside of the lexan that will fit up against the emblem the closer you can get the the edge the brighter it will be.
I forgot to take a pic but i drilled a hole through both of them for the wire to come up through.
Now that I have the channels cut out its time to lay the wire in. I got my wire from elumiglow.com but you can get it from thatscoolwire.com. (YOU HAVE TO BUY 1.4mm WIRE ANYTHING ELSE IS TO BIG TO MAKE THE TIGHT BENDS) The reason I chose elumiglow was because the research I did said that they had the brightest wire but they don't have red. Thatscoolwire does have red. You will also need to buy a transformer and and some connectors. I called them and they put it all together for me so all I had to do was plug it in.
I just superglued the wire in to held it in place till I was finished
Once I tested them the make sure they worked it's time to glue them to the back of the emblems. I used E6000 glue I got at Walmart and this stuff is ridiculous strong when dried. On the front I generously filled in the channel and then clamped it to the emblem. Using a wet paper towel I cleaned up the excess glue that came out. For the back I pretty much did the same except I also filled in the letters as well to fill the void.
I let them sit over night and I tested one more time before I put them on. The front I glued on using the E6000 and on the back I just screwed them back on. I wired the front to the side markers and I wired the back to the liscence plate light if you wanted to do it as a third brake light you could wire it the the brake wires
Old Apr 5, 2015 | 04:49 PM
Richard Cooper's Avatar
Richard Cooper
VERY nice job!
Old Apr 5, 2015 | 05:23 PM
MrJlr's Avatar
MrJlr
Freaking awesome
Old Apr 5, 2015 | 05:50 PM
DUB's Avatar
DUB
Not many custom 'things' recently that I have seen impress me...but this does. REALLY NICE.
DUB
Old Apr 5, 2015 | 06:08 PM
VetteMarshal's Avatar
VetteMarshal
Very cool.
Do you make them in red?
Old Apr 5, 2015 | 06:15 PM
Danny.reamer
Dub thank you very much I appreciate
Vettemarshal you could make it in red I just choose to do blue I plan on painting mine blue evintually so I just wanted it to match. The place I bought my wire didn't have red but you can get it from thatscoolwire but it has to be 1.4mm wire
Old Apr 5, 2015 | 06:58 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Very cool and creative! I love seeing thinking outside of the box and the Eckler's catalog!!!
Now my mind is racing with the possibilities for this stuff!!! Damn you!!!
Old Apr 5, 2015 | 07:22 PM
KIKIRIKI's Avatar
KIKIRIKI
sweet
Old Apr 5, 2015 | 07:29 PM
kanvasman's Avatar
kanvasman
Thanks for taking the time to get pics and write this up in a simple to understand set of directions. I am printing this thread out s I don't loose it. Excellent work.
Old Apr 5, 2015 | 07:39 PM
Brack c's Avatar
Brack c
Thanks for sharing ...Cool little custom job
Old Apr 5, 2015 | 08:09 PM
Smadoo's Avatar
Smadoo
That is awesome! I may do one in red and connect it up as a brake light.
Old Apr 5, 2015 | 08:42 PM
Richard454's Avatar
Richard454
NICE!!!! WOW- now that's a labor of love!!
Here's a Bowtie- for less than 10bucks-
They also sell pre-cut pieces for other cars- here's one in red for about $10.
And here's some two color ones- the Bike guys are using these...I was thinking doing something w/ my "Stingray" side emblem and it would double as a turn indicator.
Old Apr 5, 2015 | 09:06 PM
Danny.reamer
Yea these are kinda how I got the idea but you won't find any that is for the corvette
Old Apr 5, 2015 | 09:15 PM
Kris Tunetso's Avatar
Kris Tunetso
Nifty.
Old Apr 5, 2015 | 09:17 PM
Richard454's Avatar
Richard454
I was just going to get a BMW one and be done w/ it!!!
I had looked at doing my rear letters as well- but dang that's a LOT of work- especially since mine are not connected!!!
My hat's off to you!!!
I was also thinking a scroll saw would be the ticket to cut the Lexan.
Richard
Old Apr 5, 2015 | 09:35 PM
Danny.reamer
Richard
Yes yours would be a major pain since they are not connected
Old Apr 6, 2015 | 02:10 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Super idea and a very nice job. I like the look, but wonder how that blue light will show against a blue background after you paint your car?
Paul
To Lighted Emblems ( HOW TO(
Old Apr 6, 2015 | 06:57 AM
Tooonz's Avatar
Tooonz
This is the coolest thing I've seen in a while. We can make these in the shop
Old Apr 6, 2015 | 09:27 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
Outstanding!...Excellent!...Clearly well thought out and executed idea!...thanks for sharing...Good Luck and keep us informed...!
Old Apr 6, 2015 | 09:54 AM
VetteMarshal
Richard
I was thinking the same thing. I may use mine to do this when I insatll my rear emblem.
