Identifying Hose
Old Apr 6, 2015 | 12:26 AM
djrasras's Avatar
djrasras
Default Identifying Hose
Can anyone identify the hose in this picture circled in red? On my 79 vette it is not clamped on whatsoever, so you can literally just pull it off without any effort. I just put zipties on both ends to keep it on, but should I replace it for the long run?
Old Apr 6, 2015 | 12:32 AM
dugsgms74's Avatar
dugsgms74
Part of the EFE system, goes from the air cleaner to a stamped housing bolted(riveted?) to the exhaust manifold to get preheated air into the engine on cold start.
Old Apr 6, 2015 | 07:26 PM
Paul L's Avatar
Paul L
The part on the exhaust manifold is called a heat stove. Keep it; pretty rare these days. That hose is typically ribbed metal and any local parts store can get it. Less than $5.00. As said above it aids in cold start heat-up.
When I had my 1979 (years ago) I always painted it with flat heat paint.
Old Apr 7, 2015 | 02:08 AM
djrasras's Avatar
djrasras
Ok thanks guys. Is there any specific part number I can use to order it online?
Old Apr 7, 2015 | 09:01 AM
Paul L's Avatar
Paul L
All vendors will have different numbers but here is one example.
http://www.zip-corvette.com/catalogs...sult/?q=EH-449
Old Apr 7, 2015 | 09:16 AM
BKarol's Avatar
BKarol
or you can save on shipping by checking your local auto parts store and ask for a "preheater hose" (or search yourself). You would need to know the diameter and length and they do come in black. FYI.
Old Apr 7, 2015 | 09:53 AM
Paul L's Avatar
Paul L
Quite true; e.g. NAPA NOE 8191130.
Old Apr 7, 2015 | 12:47 PM
7T1vette's Avatar
7T1vette
For that duct to be of any use, the vacuum operated damper on that air cleaner inlet must be working as intended. When engine is 'cold', that damper should close off the inlet tube so that only warm air through that duct (from the exhaust manifold) is entering the air cleaner. Once the engine warms up (and temp sender turns that vacuum damper OFF), that damper should be fully open.
If that damper no longer works, that duct is of no use other than for appearance purposes.
Old Apr 7, 2015 | 12:59 PM
djrasras's Avatar
djrasras
Ya I feel like the damper is not working since after changing out the battery, starter, intake hoses, and alternator, I still have trouble starting the car. I have to turn the key and floor the gas peddle every time. How can I check to see if the damper is working?
Old Apr 7, 2015 | 01:11 PM
Duane4238's Avatar
Duane4238
That pre-heater system does absolutely nothing to help you "START" your engine. If you have to floor it, it sounds like you have a choke problem. After your car is started and running, that system pre-heats incoming air to aid in better driveability when the engine is cold. As soon as the engine reaches the proper temp. that system turns off. Your starting problem is not in that system.
Duane
To Identifying Hose
