Can i grind out the scratches and buff and paint them?
Whats are they chrome, anodized Ali, Stainless?
The sills are clear anodized aluminum.
You can sand out any scratches but to buff them you'll need to remove the anodize in those areas. Chemical stripping is fairly easy and cheap.
A like scuff on the painted areas and you can re-paint.
You may want to check the price on new ones before you invest a lot of time in refurbishing the old ones. Then again, looking at your location, maybe not.
Years ago you could buy a special cloth buffing wheel that was impregnated with industrial diamond dust. They were round white cloth pieces stitched together to form 1/2" to 1" wide "wheels". It fit onto your bench grinder as a grinding wheel would fit, and would remove scratches from any metal that was not flame-hardened without gouging the metal like a sander would. It would polish stainless steel and aluminum to imitate chrome plating. Check the local industrial supplier in your area to see if the buffing wheels are still made. They are not messy at all like the cloth buffing wheels that you apply the polishing compound to, and polish metal much faster.
Have the buffing gear so, have given it a go. As shipping fr new ones will be $100.
So scratched had to take anodizing off about 3 hrs of work..... looks good now but if oxidizaton dulls them to much will have to buy new ones.
For future reference, you can strip the anodize off using drain cleaner crystals and water. Use the ones with all the warnings not the eco stuff.
Use a test meter to see when the anodizing is gone, anodizing is not conductive so when you can get a reading between different spots you know it's bare.
Then sand/buff
A good polish with something like flitz, blue magic or something along those lines (should be able to smell the ammonia in it) will protect those for quite a while with just a quick once over now and again.
As inexpensive as those sills are, just replace them. You can't really grind/sand out any deep scratches and get the part to look right afterwards. Just my .02.....
Too bad you can't find those cloth wheels...they would have removed the anodize and scratches at the same time leaving a super shine.
The red tripoli polish and a buffing wheel will do the job. Bunnings have it in Dunedin so I would expect they would in Auckland too. You can spray them with a clear acrylic if you don't want to keep polishing them.
