Jack Points for 79 Corvette C3
Old Apr 24, 2015 | 02:23 PM
jokerman2k's Avatar
jokerman2k
Default Jack Points for 79 Corvette C3
Just brought a 79 Corvette after unloading my 84 C4 (the pinto of Corvettes) so I'm looking for where I can put the jacks under this model. I know they have certain spots where you can only left from.
Any help on these points?
Thanks,
Jokerman2k
Old Apr 24, 2015 | 04:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your owner's manual and the jacking instructions on the rear compartment door show the recommended jacking points. Essentially on the frame in front of the rear wheels and on the frame behind the fronts.
Old Apr 30, 2015 | 02:44 PM
jokerman2k's Avatar
jokerman2k
Thanks, but not sure many 79 Vette's come with a Owner's Manual after trading hands for (36)yrs. But thanks I now have places to look.
Old Apr 30, 2015 | 03:54 PM
Paul L's Avatar
Paul L
This may help. I have done this scores of times. Good luck!
Old Apr 30, 2015 | 06:24 PM
AboveTheLogic's Avatar
AboveTheLogic
I usually use the jack points illustrated above for my jack stands, and actually jack the car up from the rear differential or center of the front crossmember.
Old Apr 30, 2015 | 08:00 PM
Paul L's Avatar
Paul L
How do you prevent dents in the front cross member? A block of wood?
Old May 1, 2015 | 09:35 AM
AARRA's Avatar
AARRA
I had the same concerns, particularly after reading the many threads on the Forum and all of the advice, T-tops off, doors open, etc. I have 2 jacks and 4 jack stands but then decided to buy race ramps. Not that expensive considering the money I have spent on the car, and I feel very comfortable using them. Just a suggestion.
Old May 1, 2015 | 12:51 PM
Easy Mike's Avatar
Easy Mike
...not sure many 79 Vette's come with a Owner's Manual after trading hands for (36)yrs...
Order a reprint. All the vendors carry them. Lots of valuable information in the owner's manual.
Old May 1, 2015 | 03:41 PM
GaToy's Avatar
GaToy
I have a 1/2" piece of solid rubber that I put between the jack and the cross member. It's never left a mark.
Old May 1, 2015 | 04:29 PM
Paul L's Avatar
Paul L
Thanks for the reply. Makes sense. There is a special tool to remove dents from that cross member.
https://www.corvetteforum.com/forums...mber-dent.html
Old May 1, 2015 | 08:31 PM
hotrodnick's Avatar
hotrodnick
If you're going to leave it on jack stands for a period of time use the front jack stands. That will keep the front from drooping and may stop some fiberglass problems.
Old May 2, 2015 | 03:17 PM
AboveTheLogic
Fortunately for me, the crossmember was already dented up!
I use a race jack from harbor freight that has a rubber pad on top, it doesn't seem to be making any new dents.
Old May 4, 2015 | 07:55 PM
jokerman2k's Avatar
jokerman2k
All good stuff. Thanks everyone love the pics, very helpful.
Thanks,
Jokerman2k
To Jack Points for 79 Corvette C3
