69 corvette under body insulation
Old Apr 27, 2015 | 09:37 AM
Mikesfreetime's Avatar
Mikesfreetime
Default 69 corvette under body insulation
Would anyone happen to have pictures of the under body insulation installed? I picked up the left and right side and can not see where it lays correctly, maybe a picture would help me.
Old Apr 27, 2015 | 10:33 AM
Alan 71's Avatar
Alan 71
Hi mft,
These are from a current post.
They're from a restored car perhaps they'll help.
Regards,
Alan
Old Apr 27, 2015 | 10:48 AM
Mikesfreetime
Originally Posted by Alan 71
Hi mft,
Regards,
Alan
That is helpful but I dont see how this part has that much coverage? Does the widest side go to the front of the car?
http://www.zip-corvette.com/catalog/...on-11-495bb4/#
Old Apr 27, 2015 | 11:42 AM
Alan 71's Avatar
Alan 71
Hi mft,
I guess you'll need to look at your car for the clips mentioned in the ZIP description.
Those clips (or the holes for the rivets that mount them) should give you an idea where the insulation goes.
There were various iterations of the type, amount, and location of the insulation and shields in 69 as production went on. So it can be a bit of a puzzle.
Regards,
Alan
Old Apr 27, 2015 | 11:51 AM
Mikesfreetime
Very true, many iterations. I held in up several different ways and none seemed correct.
Old Apr 27, 2015 | 11:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If memory serves, the AIM shows the shields and brackets, but not the actual blanket insulation.
Old Apr 27, 2015 | 03:52 PM
Mikesfreetime
Thats correct, It doesn't actually show the insulation layout
Old Apr 27, 2015 | 05:23 PM
SB64's Avatar
SB64
The 2 pieces of insulation I picked up at ZIP seem to be flat and stiff. Is that correct or is it soft and more like a blanket? The pictures by the way are great, thanks Alan for those.
zio
Old Apr 27, 2015 | 07:12 PM
1967427TRIPOWER's Avatar
1967427TRIPOWER
Cruising
Mike, those pictures posted are from the car i'm just finishing, there are 3 parts to it ,if you can post a picture of the items you have and i will be glad to help you piece it together, its not that bad but yes it does get confusing ,
Old Apr 28, 2015 | 08:19 AM
Mikesfreetime
Here are the parts I have. The first part has a left and right.
Old Apr 28, 2015 | 08:28 AM
SB64's Avatar
SB64
Okay, those are the same items I have. It just looks so different under the car. Thanks for that info. I assume it would be best to install before dropping the body back on if possible.
R
Old Apr 28, 2015 | 08:35 AM
Mikesfreetime
R
So you havent figured out how they lay under the car either?
Old Apr 28, 2015 | 08:38 AM
SB64's Avatar
SB64
Although I am not up to that step just yet I am using your post to tell me. I have everything but have not yet looked at it all. Hope it's not to hard. Have had my share of hard!
r
Old Apr 28, 2015 | 08:45 AM
Mikesfreetime
r
Interesting, looking back on your thread just now I see this picture. Makes me wonder if the small end comes up to this point?
Old Apr 28, 2015 | 09:01 AM
SB64's Avatar
SB64
Mike if you need more pictures I can take them.
r
Old Apr 28, 2015 | 09:05 AM
Mikesfreetime
r
My insulation on the underside was shredded so If you have any showing the insulation still installed it may help our questions along.
Old Apr 28, 2015 | 01:12 PM
SB64's Avatar
SB64
Default Insulation
Hey Mike, I went out and removed the plastic shield to see if we could get a better look. To me it looks like angled part is close to the tunnel and the straight side is on the out side. So I think the piece you show is the drivers side. What do you think?
r
To 69 corvette under body insulation
Old Apr 28, 2015 | 01:48 PM
Mikesfreetime
r
That looks like it could be the case.
Old Apr 28, 2015 | 02:11 PM
Alan 71's Avatar
Alan 71
Hi mft,
The second picture you posted is the transmission 'blanket'.
It's an easy install since it just fits one way.
r's photos show the location for the other two pieces pretty well.
Regards,
Alan
Old Apr 28, 2015 | 08:30 PM
1967427TRIPOWER
Cruising
yes they look like the ones i get from wilcox, i PM you on some tips
