lubricating cables
Old May 1, 2015 | 03:50 PM
GaToy's Avatar
GaToy
Default lubricating cables
I have found an adapter to grease speedo and tach cables. It screws into the cluster end of the cable and has a grease fitting. What would you shoot into them? I have heard of people putting dylithium grease in speedo cables but have never seen it in a container that could be used with a grease gun.
Old May 1, 2015 | 03:57 PM
MelWff's Avatar
MelWff
you don't want to lubricate the cluster end because if it travels into the speedo or tach it will damage them. If you lubricate the non-cluster end it will travel through the cable. Use graphite lube.
https://www.corvetteforum.com/forums...tructions.html
Old May 1, 2015 | 04:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by MelWff
...Use graphite lube...
Roger that.
Old May 1, 2015 | 06:30 PM
GaToy's Avatar
GaToy
To lubricating cables
