PICS needed ,,, Fan relay locations
Old May 3, 2015 | 08:11 PM
diehrd's Avatar
diehrd
Default PICS needed ,,, Fan relay locations
Where did you locate your fan relays ? Pics of area you chose would be great ...Thanks in advance
Old May 3, 2015 | 08:37 PM
70BBvert's Avatar
70BBvert
Passenger side fender skirt
Jim
Old May 3, 2015 | 09:52 PM
Richard454's Avatar
Richard454
Mine are disguised as a voltage regulator- Bosch relays hidden inside- and was sealed from weather.
DSCN5180 by richardhayes454, on Flickr
Old May 3, 2015 | 10:53 PM
diehrd's Avatar
diehrd
cool thanks .. sorta what i had in mind ...
Old May 4, 2015 | 01:12 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
On the left hand headlight support cause it's close to the wiring harness access between the inner fender and Rad mount. I then wired both relays,along with the electric head light control to a Junction block up front installed between the two light assemblies on the inside nose and then ran one 8Gauge wire from the junction to battery..
Old May 4, 2015 | 07:54 AM
Mooser's Avatar
Mooser
back side of driver fender
M
Old May 4, 2015 | 08:50 AM
Richard454's Avatar
Richard454
I did something simular as well for the power-
I have the horns/upgraded headlights/electric headlights and fans running off a 4Gu wire and used a post on the front of the rad support-
DSCN5170 by richardhayes454, on Flickr
I used combo fuse holder/relay blocks to control the headlights high/low beams on one side- and on the pass side to control the headlight lifts and horns-
DSCN5160 by richardhayes454, on Flickr
DSCN5162 by richardhayes454, on Flickr
Old May 4, 2015 | 05:25 PM
redcruz1120
St. Jude Donor '09
Nice set up. Question. When you say Horns, what exactly do you mean? Reason I was asking is because i thought if it was the horns that im thinking about , they would just need the existing green wires that comes with the harness. Or are they something different?
Old May 4, 2015 | 06:44 PM
Richard454's Avatar
Richard454
Thanks!
There's very little of the factory harness in my car-what's left, I ran inside some AN12 SS line to hide- basically I am using the factory wires just to trigger the relays.
I used the negative wire off the harness (from the horn button) to trigger the horn relay- I did away w/ the horn relay junction box. So I have the relays up front triggering two sets of Fiamm horns (off a BMW 750IL)- one set tucked away on each side up under the front fenders -above the turn signals.
Whats left of the factory harness-high/low beam,horn,turns,parking and the headlight ajar wire.
DSCN5151 by richardhayes454, on Flickr
Inside w/ SS hose-
DSCN5154 by richardhayes454, on Flickr
here's one set of the Fiamm horns- the other set is on the driver side. Nice and LOUD!!
DSCN5124 by richardhayes454, on Flickr
Engine harness-Before
DSCN2752-1.jpg~original by richardhayes454, on Flickr
After- Hid the wires under the polished aluminum U tube-
DSCN5168 by richardhayes454, on Flickr
To PICS needed ,,, Fan relay locations
