Pulleys for 77 corvette
Old May 7, 2015 | 11:57 PM
My 77 corvette's Avatar
My 77 corvette
3rd Gear
Default Pulleys for 77 corvette
I have a 77 corvette and I'm trying to put the correct pulleys back on the engine. The alternator was on the right side instead of the left, so I installed it back on the left. Now my pulley is not lining up with the harmonic pulley. The first groove is about one inch from the balancer. What is the correct pulley for that year????
Old May 8, 2015 | 07:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have the assembly instruction manual (AIM) for 77? The AIM shows the factory installation of the pullies, lists the original GM part number for them, and shows the required brackets.
Old May 8, 2015 | 10:59 AM
My 77 corvette
3rd Gear
[QUOTE=Easy Mike;1589586985]Do you have the assembly instruction manual (AIM) for 77? The AIM shows the factory installation of the pullies, lists the original GM part number for them, and shows the required brackets.
[/QUOTE Yes I have the assembly manual and will look again. Thank you
Old May 8, 2015 | 11:01 AM
My 77 corvette
3rd Gear
Yes I have the manual and will look again. I'm a newbie in here so bear with me......
To Pulleys for 77 corvette
