L82 question...
Old May 10, 2015 | 05:14 PM
ThePabst's Avatar
ThePabst
Default L82 question...
A few of my hoodlum buddies and I were bench racing and bench wrenching down at the local watering hole today...
My question to the panel is, once and for all: Can a 78, Silver Anniversary L82 be a two bolt main? I say 'yes' as long as it has 10 to 1 compression and a forged crank... Lets have it!
Old May 10, 2015 | 07:30 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
As far as I know, all L-82s are 4 bolt main.
Old May 10, 2015 | 07:33 PM
Paul L's Avatar
Paul L
Agreed.
Old May 10, 2015 | 08:10 PM
ThePabst's Avatar
ThePabst
Originally Posted by paul 74
Agreed.
Here is where this thread really starts... My father gave me his 78 SA. It was his pride and joy for years.
He bought it from a 'reputable' dealer near New Port Riche, FLA. I have the original independent parasail saying that this is indeed an original car and it was sold to him as adverti$$$ed.
I have been real busy getting this rig back into shape. In my travels under the hood, I found this motor has a two bolt main.
I am going to "flame" this inspector by name and business on ALL outlets, as well as the selling dealer if they ripped my father off. Its important that I am right.
If these guys are sum-bags I want to make sure they and everyone else knows it.
Old May 10, 2015 | 08:40 PM
Revi's Avatar
Revi
Does the VIN indicate an L82 engine was originally installed? (The fifth digit in the VIN should be a "4" if it was delivered with an L82.)
Does the VIN and Engine Stamp Pad match?
Where does the tach redline at?
Last time I checked a 78 L82 only has 9:1 c/r.
http://www.corvsport.com/Corvette/C3..._1978_VIN.html
If you open this link and go to page 43 of the .pdf, look under Engine-Crankshaft, you'll see a line that reads "No bolts/main brg. cap" and the number "2" for both L48 & L82.
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Old May 10, 2015 | 08:42 PM
BKarol's Avatar
BKarol
Out of curiosity what does the engine stamp pad show. Suffix for a 78 L82 4spd is CMR. CMS for an automatic. Does it also show your partial vin?
Tach red line:
L48 & L82 w/ac the same
L82 wo/ac was higher
Old May 10, 2015 | 10:04 PM
Vet76te's Avatar
Vet76te
All L-82's were 3 bolt mains. You can tell if the car is a factory original L-82 by the VIN number. You can tell if it has it's original engine by the engine ID number, (should match the cars VIN#).
Of course, the engine number can be restamped.
But I'm positive....ALL L-82's were 4 bolt mains.
Old May 10, 2015 | 11:43 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Doing a little research into your earlier posts, going way back to May 2011, you state this 78SA is an L48.
Why do you now think it's an L82?
Seems most folks that are unsure if they have the L82........don't.
I got way too much time on my hands
Originally Posted by ThePabst
She is a TRUE Silver Anny, L48, 4H twixt the silver seats and T tops... like I said, I will drive it all the time. That is truly what they are made for and I have never ever believed in trailor queens.
Old May 10, 2015 | 11:50 PM
news2me's Avatar
news2me
Yep, All L-82's are 4 bolt mains..
Old May 11, 2015 | 12:10 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
This is getting interesting now.
Old May 11, 2015 | 05:15 AM
Vet76te's Avatar
Vet76te
I meant "4 bolt".
Old May 11, 2015 | 07:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I found this motor has a two bolt main...
It's likely to be a base engine L-48 with an L code in the VIN. I'd be wary of flaming anyone based on second hand information. Unless you were present at the time your father made the deal on the car, you don't honestly know who said what to whom about what.
Old May 11, 2015 | 07:25 AM
biackbenz's Avatar
biackbenz
The tach also has a small label in the lower center that designates it as an L82.
Old May 11, 2015 | 08:01 AM
ThePabst's Avatar
ThePabst
Apparently I have too much time as well...HA!
Yes I did start an earlier post as this has been an on-going question.
That older post ended up being about 50/50 yes or no. It was confusing at best, so was time spent bumping around the net.
The car has L82 badges and the 5th digit of the VIN is a 4. The red line is 5500.
Exactly what am I looking for on the engine block?
~The WRITTEN appraisal by an 'expert' hired at the time of sale calls it authentic. I have this document. What chaps my *** is that based on this appraisal, my father paid top dollar.... Top buck for a leaking, overheating, dolled up wreck with leaking shocks, butchered wiring harness, a beat frontend and a whipped cam. This dealer and his appraiser are now working under different names. I know it's always buyer beware, I get that, but if they are predators they need to be pointed out.
My dad passed the car onto me as his health is poor. It is now in very good daily driver condition. But it has taken many thousands of dollars and two full winters. It makes me angry that people out there would do this to old men with stars in their eyes. ~
Old May 11, 2015 | 09:11 AM
BKarol's Avatar
BKarol
"Exactly what am I looking for on the engine block?"
In the front of the block below the valve cover on the passenger side you will see a somewhat square block. If it is covered in grease or oil use a rag and cleaner to read the numbers. No abrasive.
Top line gives the build date and suffix. Below that is stamped a partial vin which hopefully will be yours. In this case CMR is for a L82 4spd:
Old May 11, 2015 | 09:40 AM
Dodosmike's Avatar
Dodosmike
Alpha numeric codes stamped into the block. Look near the front of the drivers side (?) valve cover. A flat area cast into the block. May or may not be a painted surface. Should have the last few numbers of the ORIGINAL vehicles VIN stamped in it along with some alpha codes in larger capital letters. Pad codes may be gone if the engine has be milled (decked).
Post pics.
Tach say L82 on the bottom of the face?
dodosmike
BAHHHH. lol. Karol's pic shows it better than I described it.
Old May 11, 2015 | 09:47 AM
ThePabst's Avatar
ThePabst
Just looked, my engine has the CMR designation... But I absolutely positively guarantee you that this motor has a two bolt main.
To L82 question...
Old May 11, 2015 | 10:11 AM
gerry72's Avatar
gerry72
You can't tell what's inside the crankcase by making observations around the engine bay. By what method did you use to make this determination? The only way to know anything for double-sure is to drop the oil pan or at least pull the front timing chain cover and run an inspection camera into the crank case. You aren't by chance coming to this conclusion by why you might have seen with the timing cover off and looking at the number One main cap, are you? That cap is a two-bolt for all smallblocks.
Old May 11, 2015 | 10:13 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Where does your criteria of 10:1 compression and forged crank come in to play as a requirement for a motor with two bolt main bearing caps?
Do you have a picture? I mean this in the least condescending way as possible, but no motor has a single "two bolt main," you typically have three main bearing caps in your 350 that are drilled and tapped to add the extra bolts to each be 4-bolt main caps.
Where is your guarantee coming from?
Old May 11, 2015 | 11:46 AM
ThePabst's Avatar
ThePabst
No condescension taken LeMans, I'm enjoying this thread!
As part of a complete referb, I put a new oil pump in her last spring. When I was installing the oil pump I noticed the rear main cap only had two bolts.
That is what sparked my curiosity. It wasn't even the engine designation per se, it was my recollection that most heavy duty GM anything, back then that shipped with a manual used a four bolt, the two bolts were usually used for Automatics. I thought that this may have had a trans swap. That's when I started to stew about the appraisal.
Those were dark days for GM back then, I wonder if a few stinkers snuck through...
