I have a 76 corvette. I have the engine and transmission disconnected. I can barely turn the rear wheels by hand or push the car by myself. I believe that it is my differential that is really tight. Does anybody know why this is happening and if there any solutions? Also is this bad for the car (extra wear/ hurt mpg/ hurt performance)?
Yes, something is not right. On my 70 frame build up, I can easily turn the rear wheels by hand...This causes rotation in the half shafts and the differential and rotation with the drive shaft.
Yes I agree something has to be wrong. When I bought the car I was told that the original differential was broken and that he replaced it with a 3:70 differential. Are there any adjustments that can be made on the differential?
There are plenty of adjustments for the gearset and bearings. But if it was done wrong when the diff was built the parts are ruined. For instance, you can over tighten the pinion nut which will make the pinion bearings bind. If that happened the bearings are toast and need to be replaced.
I just disconnected the axle halfs. The differential spins very freely. I have the brakes all disconnected. It must be the rear wheel bearings. Would I be able to replace these in my garage?
Rear wheel bearings are not like the fronts. It is possible to do yourself but unless you're ok with a learning curve and have access to a press you may want to farm it out.
My e-brake shoes were stuck so tight onto the hub that the left rear wouldnt turn when it was pulled onto the flatbed trailer. Ask me how fun it was to get the rotor off later.
