My "somewhat of a" restoration / mod
#203
Rajin, you gone and done it now! Ls3, tanks inc, sharkbite, coilover fronts, wilwood ...it's gonna be awesome!
Btw... I would clean that frame by hand, etch and epoxy prime, then paint with this...http://shop.masterseriesct.com/produ...3&categoryId=1
It's impossible to get all the sand out of the inside of the frame, there will be raw places left inside the frame, and powdercoat isn't as solvent resistant as the ag111. IMHO
#205
#206
Heading to the frame shop in the morning. Just wanted to add that removing A-arm bushings bite the big one... Last set I removed was from a 1967 Chevelle back in 2005. I think I cut those out with a torch. Now I remember why I put the chassis last.
MISTERZ06 (04-21-2017)
The following 2 users liked this post by rajin cajin:
Metalhead140 (04-22-2017),
The following 2 users liked this post by Jack605:
MISTERZ06 (05-14-2017),
rajin cajin (04-21-2017)
Metalhead140 (05-15-2017),
rajin cajin (05-12-2017)
#211
Looks great! Worth the work! It will be completely sensational!
#212
#213
I'll just add that in my reading of threads affiliated with Brake Lines, the standard metal are at times preferred to SS because of being easier to work with and I think seating them is easier. From this, I've decided that would be the direction I'm headed on my rebuild. The original set has lasted 47yrs, so it works for me.
Keep up the good work.
rajin cajin (05-13-2017)
#214
Nice job.
Thanks and agreed. The SS are pricey, and I think overkill. The car sat for a while and the gas tank was full of pin holes and rotting out. I was getting trash in the filter from the fuel line (I replaced the tank), but it cleared itself after a few months. Like you said, the standard lasted 46 years easily. Brake lines looked fine also. The chassis on this car was solid with original factory paint in some areas, so I assume a northern car would be a different story.
#215
Received 3,220 Likes
Looks like it'll be ready for "Cruisin the Coast"!!!
It turning out great-
I just replaced the brake lines in my 73 (original) with steel and they showed no signs of rust. Went on with no issues.
On my 71 I had some SS ones-they were a pain to get seated- as any slight difference- making them flex a little was frustrating. I ended up replacing them with "NiCopp" (Nickel -copper) lines as it's way easier to flare and bend.
The following 2 users liked this post by Richard454:
#216
Richard, your work is outstanding as usual. I'm putting in a hour or so every evening to get the chassis finished up. Definitely shooting for Cruisin the Coast. Oct 1st-8th this year. You still planning on making it down??
#217
and like your work isn't outstanding as well?!!!
The Cruisin the Coast is almost a definite-
My friends that I have done the HRPT for the last 3 years aren't doing it this year-but getting a house for the week of CTC.
My goal is the 73 for the HRPT and the 71 V12 for the Coast.
I'll either text or email in a few weeks when the wife starts lining up a hotel.
now get back to work!!!!
rajin cajin (05-27-2017)
#220
Thanks.. Went to a local car show today on the beach. A hand full of vert C3's. Got me really motivated as it was clear blue skies, white sand and in the 80s. Hopefully have her back on the road in a month or so as summer is here, and I'm itching to cruise.
