what do you think ?
Old May 22, 2015 | 06:27 PM
upnorth's Avatar
upnorth
Default what do you think ?
I have a 1976 corvette . don't run it much . took it or a 40 mile round trip today . ran the 20 out fine . coming back after it sat for about 30 minutes started right up went about 2 blocks went to pull out and it stopped dead . had just put a new battery in it a couple weeks ago . it would crank had spark and was getting gas . after about 30 minutes I tried it again and it started right up and ran fine all the way home . any ideas what to look for ?
Old May 22, 2015 | 06:40 PM
The13Bats's Avatar
The13Bats
vapor lock?
overheated coil?
loose wire?
DUB's Avatar
DUB
A 'glitch'. Drive it some more and let it get hot and see if it does is again. I would do inner city or residential driving...more stop and go driving than interstate driving. I know this is not giving you anything to check....but if it has not been driven in a while....and you know for a fact that you had a GOOD SPARK (there is a difference)...and you know that you had fuel ....and we all know that the air is a given. 'Something' failed. I would think that it may be more ignition related....because I do not know how it died.
DUB
Old May 22, 2015 | 06:49 PM
The13Bats's Avatar
The13Bats
Hard to trouble shoot,
I have a vw trike did this with a loose ground.
Knew of a dodge that had a ign switch issues that would do this.
We rebuilt the edelbrock on a buddies air boat that was doing this fixed it but we really do not know how, and it appeared before the carb overhaul to be getting fuel...
Old May 23, 2015 | 08:20 AM
upnorth's Avatar
upnorth
I try some of these . the only thing different on the car is last year I went from a electric fuel pump back to a mechanical one
Old May 23, 2015 | 11:30 AM
upnorth's Avatar
upnorth
was playing with it a little bitt today . could I have to much fuel pressure with the new pump for a holley 600 . at idle I notice that the second two barrels were dripping quite a bit of gas and had a hard time keeping it running at idle .
Old May 23, 2015 | 03:24 PM
upnorth's Avatar
upnorth
pretty sure I found it was a stuck rear float. opened the fuel level screw on the side and fuel poured out tapped on it a couple times put it back in started it up and no more dripping fuel at lease so far . running smooth at idle will take it out for a road trip probably 5 miles back and forth a few times .
Old May 23, 2015 | 06:53 PM
DUB's Avatar
DUB
YEP...that dripping fuel will do it....that is for sure. Seems like you found the problem.
DUB
To what do you think ?
