A Pillar Molding Attachment
Old May 25, 2015 | 03:53 PM
Too Slow '90's Avatar
Too Slow '90
Default A Pillar Molding Attachment
My '68 roadster is missing the attachment tabs (plastic that looks like Velcro) that are supposed to be installed (with rivets) on the windshield pillars. I have searched the Internet as well as the forum and can only find the ones that go on the door panels or T-tops. There is nothing to attach the new moldings. the ones I removed were glued on. Does anyone have a source for these? Thanks.
Old May 25, 2015 | 05:41 PM
Alan 71's Avatar
Alan 71
Hi TS,
The original tabs were pop-riveted in place.
I believe the oval velcro tabs now available can be drilled and mounted using 1/8" diameter pop-rivets.
I'd file the head a little flatter and experiment with how long the shaft needs to be to get a good 'set' without going too far into the foam padding so it makes a bump visible from the vinyl side.
Good Luck!
Regards,
Alan
Remains of drilled original pop rivets.
New tabs pop riveted in place on reproduction trim.
Old May 25, 2015 | 06:35 PM
Too Slow '90
Alan,
Thanks for responding. I am looking for the ones that attach to the windshield frame of the car. Are they the same? I bought new moldings but there is nothing on the car to secure them. What are they called? I can't seem to locate them. Thanks.
Originally Posted by Alan 71
Hi TS,
Good Luck!
Regards,
Alan
Old May 25, 2015 | 08:10 PM
loup68's Avatar
loup68
Army
On the forum here, was a thread that very early 68's had one or two screws to hold the pillar trim on. No plastic velcro. Lou.
Old May 25, 2015 | 08:45 PM
Too Slow '90
Thanks. Mine is an early car however it has the rivet holes..just no Velcro tabs.
Old May 26, 2015 | 08:02 AM
Alan 71's Avatar
Alan 71
Hi TS,
Look for the loose oval velcro tabs in the roof panel repair section of the catalogues.
Regards,
Alan
Old May 26, 2015 | 11:20 AM
Too Slow '90
Thanks.
Hi TS,
Regards,
Alan
To A Pillar Molding Attachment
