Rear window trim question
Old May 29, 2015 | 04:51 PM
overBlown's Avatar
overBlown
Default Rear window trim question
The plastic piece held on by screws that borders the back window on my 75, is there supposed to be weatherstripping of some kind that goes between it and the glass? There's a gap that looks strange and it rattles at certain rpms driving me crazy. Just so we're clear, I'm not talking about the seal of the rear glass itself, that's all fine. I'm talking about the plastic strip that borders it on the interior. I'll add a picture.
Also, it's a small block 350 with a TH400. Even if flooring it, with the shifter in drive it shifts to 2nd at 3500rpm, no higher. 2nd shifts fine at 5500rpm. If I put the shifter into 1st and floor it, it shifts great right at 5500 on it's own. Any ideas? Thanks!
Old May 29, 2015 | 04:58 PM
overBlown's Avatar
overBlown
Old May 30, 2015 | 06:11 PM
overBlown's Avatar
overBlown
Anybody?
Old May 30, 2015 | 07:47 PM
gjohnson's Avatar
gjohnson
My 76 was the same. I believe its original. I have since put in a removal rear window from a '72
Old May 30, 2015 | 10:03 PM
Peterbuilt's Avatar
Peterbuilt
Default You made me look!
No spacers, the side screws go into the body.
Old May 31, 2015 | 12:38 AM
thegavel's Avatar
thegavel
Same on my 74.
I just used some black (adhesive foam) draft stopper (house door seal) on mine.
Stopped the rattle.
Cheers,
Gav
Old May 31, 2015 | 03:16 PM
overBlown's Avatar
overBlown
Thanks guys! I'll come up with something.
To Rear window trim question
