70 coup rebuild
Old Jun 2, 2015 | 09:40 AM
1lkydog's Avatar
1lkydog
Default 70 coup rebuild
I plan on dropping my body back on my frame this weekend. The frame with motor and trans is about 90 percent completed. The body work is done and in a primer stage minis the front clip which has been mention before. New clip when it goes back to bodyshop for paint. Now I need to know what all needs to be done before the body goes on. I have the trans tunnel insulation in place and pos. battery cable run under the body and also the park brake cable. On frame I have both the gas and brake lines on. Have the bell housing foam and the frame rail foam heat parts ready to put on. Any thing else that needs to be done that one can not get to after the body is on. Do not want to lift any more than I need to. Thanks now for any input.
Gary
Old Jun 2, 2015 | 11:16 PM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Sounds like a cool project. You've covered everything I could think of, particularly the brake and gas lines.
Old Jun 2, 2015 | 11:38 PM
13611's Avatar
13611
https://www.corvetteforum.com/forums...orum-help.html
See if this link works... I asked the same question a while back and got some really good info!
To 70 coup rebuild
