1980 - 81 hood question
Old Jun 8, 2015 | 06:05 PM
BurnedVette1980's Avatar
BurnedVette1980
Default 1980 - 81 hood question
Are the hoods identical from 80 through 81 not only in appearance but fitment as well? My reason is that my paint and body guy said that the hood lines up in the front but has a 2-3 inch rise near the windshield. He had multiple people look it over and cant seem to figure out why it has the rise. So a new hood is in order I believe. I found a GM original hood for an 81 and was wondering if it was a simple fit for my 80. Thanks!
Old Jun 8, 2015 | 06:57 PM
DUB's Avatar
DUB
1980 and 1981 hoods are the same....the 1982 is different.
Posting photos of your issue would be helpful also. "Seeing' what you and your body guy are seeing...helps out.
DUB
Old Jun 8, 2015 | 07:09 PM
BurnedVette1980
It might be hard to see but the hood is latched in this picture. You can see where the hood meets the front quarter panel it does not come close to lining up. He thinks at some point something heavy was set on the hood to bend it upwards like that, but I find it hard to believe that this fiberglass would do that. Side-note, this car was involved in a fire in the rear but the flame did not spread to the hood but it is possible that a good amount of heat got to the hood.
Old Jun 8, 2015 | 07:14 PM
redvetracr's Avatar
redvetracr
I have a hood off an 80 available, click the link to my ad and if your interested send a PM.
https://www.corvetteforum.com/forums...tte-stuff.html
Old Jun 8, 2015 | 07:16 PM
BurnedVette1980
Thanks red, I may be in touch. Where are you located?
Old Jun 8, 2015 | 07:48 PM
redvetracr's Avatar
redvetracr
IL/WI state line, 20 miles west of lake Michigan
Old Jun 9, 2015 | 12:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have shims under the latch loops?
Old Jun 9, 2015 | 06:59 PM
DUB's Avatar
DUB
I will write this....if you are doing panel fitting...it is in your BEST interests to have the car with the wheels and tires installed an aired up and ON THE GROUND and NOT on jack stands.
DUB
Old Jun 9, 2015 | 11:01 PM
BurnedVette1980
Mike, my body guy said the shims are in place not sure if we need more shimming or not. And DUB this was the only picture I had with the hood very visual. Since this picture it has been on all fours and aired up, still looks the same.
Old Jun 10, 2015 | 07:04 PM
DUB's Avatar
DUB
Be aware that there are rubber blocks that GM used inside the hood gutter areas on each side so that these rubber block would apply pressure to the hood in certain areas to create a fulcrum and cause the rear of the hood to actually go down. Often times if the hood is down below the surface at the hood surround right above your front wheels housings...picking up on the hood in that area can cause the rear of the hood to go down.
DUB
Old Jun 11, 2015 | 02:54 PM
BurnedVette1980
So if I added the correct amount of rubber in the gutter area it could drop the height of my hood down in the rear? The front of my hood has perfect fitment in front of the wheel housings though. So would adding this rubber drop the back but raise the front?
Old Jun 11, 2015 | 03:57 PM
briankeery's Avatar
briankeery
The latches on the front corners may have shims under them. Check to see if any are there. If so, try removing some or all to bring your front corners down flush. this worked for me. The rubber in the trough had no effect on my front end corners.
Old Jun 11, 2015 | 06:47 PM
DUB's Avatar
DUB
IF your hood is FLUSH at the hood hinges.....and if the hood is FLUSH right beside where it latches to the cowl....AND....the hood is LOW BETWEEN THESE TWO POINTS.....THEN...putting a block BETWEEN these two points can raise up the side of the hood...thus causing the rear to drop..AND getting the hood flush along the side...BUT...this depends on the hood itself. IT IS NO GUARANTEE.
DUB
Old Jun 11, 2015 | 07:36 PM
BurnedVette1980
Ah! Okay thank you DUB I finally understand now. I will take a look next time I'm at the shop and try a few things!
To 1980 - 81 hood question
