Yes. Mine did on my 74. It was a tight fit but I managed to squeeze it in there.I switched my original distributor for a mechanical tack drive HEI dizzy.I even used the distributor shield.
That's what I was hoping to do too. Mine has an HEI but the previous owner got rid of the OEM cleaner for a Moroso cleaner. I want to go back to the OEM.
75 is a functioning cowl induction cleaner. They have a dent in back to clear the HEI.
73 thru 75 were cowl induction. 73 & 74 were the same. HEI was introduced in 75 so the cleaner base was modified with a larger indent to clear the big head of the HEI distributor.
