Lug bolts snapped
Old Jun 17, 2015 | 11:41 AM
Pancho07's Avatar
Pancho07
Default Lug bolts snapped
What would make 4 out of 5 lug bolts snap at the same time. Happened to my 77 last week.
Old Jun 17, 2015 | 11:46 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
your wheel lugnuts got loose....who put the wheel on last ?
Old Jun 17, 2015 | 12:20 PM
toobroketoretire's Avatar
toobroketoretire
Did you have new tires installed recently? If so the guy who mounted them may have overtightened the lug nuts.
Old Jun 17, 2015 | 12:24 PM
JimLentz's Avatar
JimLentz
Do you have wheel spacers?
Old Jun 17, 2015 | 12:36 PM
Pancho07's Avatar
Pancho07
The tires have been on it for over a year, no spacers. All 4 broke at the same time. Thought it might be my driving that caused it.
Old Jun 17, 2015 | 01:04 PM
JimLentz's Avatar
JimLentz
Were you doing the Dukes of Hazard style of driving? It takes a lot to break multiple lugs at once.
Old Jun 17, 2015 | 01:06 PM
scrappy76's Avatar
scrappy76
9 times out of 10 the studs will break either they loosened up or they were overtightened. However if your doing "General Lee" jumps with the car or slamming the wheels up against the curb, or doing a mess of burnouts, I doubt your driving had anything to do with it. Are you running steel wheels or aluminum ?
bashcraft's Avatar
bashcraft
The lug nuts were loose.
Is your driving that bad?
Old Jun 17, 2015 | 01:08 PM
qwank's Avatar
qwank
stock or aftermarket wheels?
non hubcentric wheels with the wrong nuts will make them break off also
Old Jun 17, 2015 | 01:20 PM
Condo_454C3's Avatar
Condo_454C3
^ been there done that =[
Old Jun 17, 2015 | 02:41 PM
Pancho07's Avatar
Pancho07
Everything was original. Same as it came out with. I could understand if 1 or even 2 broke but 4 at the same time. The 1 remaining lug must have been a good one as I drove it several times after they broke before I checked them.
Old Jun 17, 2015 | 05:13 PM
qwank's Avatar
qwank
I going to say loose nuts then.
Old Jun 18, 2015 | 12:51 AM
7T1vette's Avatar
7T1vette
My guess is that they were overtightened. That would cause the studs to stretch and become weaker. Under load they would then snap. Anyone with good knowledge of metal failure modes could look at the ends of the remaining stud portions to determine the actual cause.
If you can take a photo of the stud ends and post it, I'd give you my assessment.
To Lug bolts snapped
