Need a little cooling system help
Old Jun 18, 2015 | 12:50 AM
Rich123's Avatar
Rich123
Default Need a little cooling system help
Last year I put a Direct-fit Flex-a-fit Aluminum Radiator and Electric Fan in place of my stock radiator and engine driven fan. It helped keep the engine cooler than the stock system did.
Last week I let a garage swap out my seized AC compressor and clean out the system. The mech that did the work noticed that the upper radiator hose gets very hard when the engine is started. When I brought it home I checked it and sure enough the upper hose can be compressed easily when the engine is not running but it gets very tight when the engine is running.
I am hoping some one will be curious and check theirs. Does the upper hose get tight with a stock radiator when the engine is running???
BTW mine is a 1978 original stock 350.
Rich
Old Jun 18, 2015 | 02:54 AM
toobroketoretire's Avatar
toobroketoretire
Rich
Every liquid-cooled engine in the world does that. When the coolant is heated pressure in the cooling system builds and that is one of the factors that prevent the coolant from boiling; the other factor being the 50/50 mix of antifreeze and water.
Old Jun 18, 2015 | 06:58 AM
gungatim's Avatar
gungatim
I would find another mechanic...yes, the hose gets hard. Next time he works on the car for you, ask him to open the cap when it's hot, that will be a good demonstration of why the hose gets "hard" when running...sometimes people need a lesson in the basics the hard way...
Edit: Do not really do that, it is dangerous and he could get severely burned...just making a point...
Old Jun 18, 2015 | 07:43 AM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Uhh, that's normal. If it wasn't getting 'hard' then you should worry.
Old Jun 18, 2015 | 08:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I would find another mechanic....
Probably good advice.
Old Jun 18, 2015 | 09:47 AM
Rich123's Avatar
Rich123
Good point. I guess 15psi over normal atmospheric pressure would feel hard.
I assumed it was getting pressurized as soon as the car starts (cold) so this morning I pressed on the hose for a baseline of how hard does it feel, started the car and pressed it again. It felt the same both times. So what he was noticing was just the normal pressure after the car heats up. He fooled me!
Thanks for all the responses. I have had so many challenges since I bought this car, just getting it reliable so I could use it as a touring car, it just seemed like one more thing I needed to resolve.
Old Jun 18, 2015 | 10:31 AM
lurch59's Avatar
lurch59
Except for those of us running Evans coolant, who run a zero pressure system. Also, many radiator caps are not holding pressure because they don't get checked and they are malfunctioning. I recently bought an old chevy truck, checked the cap, and it wasn't holding any pressure....
Old Jun 18, 2015 | 11:10 AM
Rich123's Avatar
Rich123
I put a new cap on the new radiator and it's actually 16psi. Don't remember where I got the spec for that.
What is Evans coolant? Does it keep the engine cooler?
Old Jun 18, 2015 | 12:57 PM
scrappy76's Avatar
scrappy76
I love that last sentence.
And yes the upper hose should always be solid when the engine is warmed up and the thermostat is open.
Old Jun 18, 2015 | 01:32 PM
gungatim's Avatar
gungatim
No. evans coolant is just another brand of anti-freeze. it is an ethylene glycol mix, and is no more waterless than pre-mixed antifreeze from the store. it's boiling point is touted to be some 375 deg. F, which, of course, is the same as 50/50 anti-freeze mix off the shelf...
and it runs the same pressure in the cooling system as anything else, unless someone disables the pump or leaves the cap off...
Old Jun 18, 2015 | 08:16 PM
Paul L's Avatar
Paul L
I don't think any coolant is rated to 375*F.
Old Jun 18, 2015 | 09:06 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Freudian Slip?
Old Jun 19, 2015 | 08:18 AM
gungatim's Avatar
gungatim
my mistake, I stand corrected. at 100% it is 386* F, at 50/50 it is only 225 (STP) which is why you run pressure. I misread my chart.
either way, if you read the MSDS of the evans coolant, it is ethylene-glycol...
Old Jun 22, 2015 | 06:23 PM
lurch59's Avatar
lurch59
Evans is propylene glycol, and in fact the NPG stands for non aqueous propylene glycol. The recommendation is to test it and be sure there is less than 3 percent water. I have the recommended refractometer to test my coolant, and it is about 2% water.
Regular coolant mixed with 50 percent water boils at 265F with a 15 psi cap.
I don't know how you know how much pressure is in the system unless you have tested it, but the point is you don't have to run psi to increase the boiling point like you do for traditional coolant.
Old Jun 22, 2015 | 06:29 PM
lurch59's Avatar
lurch59
Well, it is pressure dependent. If you pressurize Evans coolant a little, I am sure it will not boil at 375. It is rated to 370F I believe, at 0 PSI.
Old Jun 23, 2015 | 06:08 PM
lurch59's Avatar
lurch59
Ok, just got off the phone with Evans Tech department. Evans is a mix of Propylene Glycol and Ethylene glycol in it's current formulation. There is no water in the coolant and they have reduced the viscosity with this blend, while retaining the properties of very high boiling points and a lifetime coolant. It also has low toxicity.
Old Jun 23, 2015 | 07:49 PM
1974CorvetteJimCr's Avatar
1974CorvetteJimCr
100% waterless coolant that is lifetime. Once installed properly per the instructions you NEVER have to change it.
To Need a little cooling system help
Old Jun 23, 2015 | 08:57 PM
7T1vette's Avatar
7T1vette
So, the Evans coolant can run to 375*F without boiling. But, of course, at that temp, your oil has turned into TAR!!
Old Jun 23, 2015 | 11:14 PM
lurch59's Avatar
lurch59
It's the coolant temps in the cylinder head near the exhaust seat that are the problem, and the boiling that can occur there. It would be interesting to find out what temperature synthetic oils turn to "tar" as you put it.
Perhaps someone can but a quart in the oven overnight and see what happens. If it does turn to tar, I can then heat up my old motor oil to 375 and seal coat my parking lot.....
Old Jun 24, 2015 | 02:12 PM
1974CorvetteJimCr
That is what makes it a low pressure system. You do not need to pressurize the system to allow it to get above the boiling point (212°F) of water. That is why a 7-pound radiator cap is all that is required.
