12 dc. Car battery or other source.
If the horn has one terminal - that's positive. Negative would then be to the horn case, if metal.
I tried it and on one horn it makes a very low, nearly inaudible tone. On the other one it doesn't seem as though it's completing the circuit. The hot lead to the wire connection, ground wire to the metal bracket or metal horn case. Using my test light I get nothing. Is there any way to rebuild these or are they no good?
Car horns draw a lot of current when powered. You can't make one work properly with a low dollar battery charger. You need to connect up to a car battery....AND you need to wear ear plugs before you connect it up. They are LOUD, if they work.
I cleaned up the electrical spade where the hot leads go and removed old paint and some rust from the mounting bracket and horn case. I have a type H and type S horn. On the type H, same result no sound of any kind. When I connect the positive side and ground it, I get nothing from the test light when I check it by touching the bracket or the horn case. On the type S, again, the same result, a low tone when I connect the positive and touch the ground wire to the case and bracket. I shook them a little thinking there might be some junk inside and I could hear something rattling around like some parts are broken. I'll probably buy the rebuild kit and give that a try.
You are using a 'test light' to check a car horn?? If you are using the test light to see if voltage is present...and it isn't...then your horn relay is KAPUT.
