Wiring questions - recognize these?
Picture 1: Dark blue wire and what looks like pink. There's a third spot in the middle which doesn't have a terminal (but maybe it should??).
Picture 2: Pink/white and green going to this 90 degree connector.
Picture 3: One gray wire to the back. This one is to the right of the shifter and looks like it needs a long plug.
Any help you can provide would be much appreciated.
Eric
Someone changed your car to a later harness???
A buddy has a 74 and I looked at his doc rebuild wiring diagram as my 69 doesn't have any of those connectors.....
The first pic with blue and pink wires and one
Empty is a oil pressure gauge wire ???? which we all know 68 had a mechanical gauge.
Pic two is part of a seat belt warming system... That's the buzzer for a 72-77 seat belt alarm 2 yellow wires 2 yellow with black tracer wires.
Pic three appears to be the lamp connector to light the PRNDL on an auto shifter.
) I have no idea was the PO was trying. From what I can tell, it has duplicates of some things and some unnecessary plugs. Remnants of two separate alarm systems and a couple (apparently aborted) stereo installs.
Still has mechanical tach and oil pressure gauge, but HEI distributor and, apparently, wiring for electric oil pressure gauge. On the plus side, I now have all exterior lights working (including signals and headlights that raise and lower), working HVAC fan, and a working speedo. Still lack wipers (wires present inside, but none to be found under the hood...), horn (easy one), any interior lights (frustrating...), temp gauge, tach and oil pressure gauge. I verified good oil pressure, but the gauge is sticky. I found reference to clean-up instructions from Wilcox on another thread, but couldn't find the info on their site. I'll keep hunting.
Also, I put one wrong picture above. Instead of the buzzer as picture 2, I meant to put the below (which I still don't have identified).
Thanks again for the help!
