Motor oil survey.
Old Jun 27, 2015 | 09:33 PM
CVO2FIXUP's Avatar
CVO2FIXUP
Default Motor oil survey.
I was wondering what engine oil all you guys were using. I just did a oil change with Mzoil z-rod 20/50 Is there better stuff out there? Whats the nonsenses.
Old Jun 28, 2015 | 01:25 AM
briankeery's Avatar
briankeery
Valvoline VR-1 Conventional 20W50 for me.
Old Jun 28, 2015 | 02:13 AM
cagotzmann's Avatar
cagotzmann
amzol z-rod 10/30, when I used the 20/50 too much valve chatter on startup. 20/50 is to thick. the 10/30 protects much better in my cooler climate.
Why did you choose 20/50 vs 10/30
The z-rod is near the top for oils for wear protection for the older corvette's/
Old Jun 28, 2015 | 02:28 AM
LT1M21Vette's Avatar
LT1M21Vette
An oil thread.
Mobil 1 15w50
Old Jun 28, 2015 | 02:37 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Castrol High Mileage 20/50.
Switched from Brad Penn 10/30.
Hot summer time cruising 20/50 protects better.
Come October she's hibernating like a bear.
Marshal
Old Jun 28, 2015 | 04:53 AM
rcread's Avatar
rcread
I use 10W30 in my newly built 355. The only people I see using 20W50 in a small block Chevy are those who are putting off a rebuild.
Old Jun 28, 2015 | 07:44 AM
zwede's Avatar
zwede
Mobil1 0W-40.
Old Jun 28, 2015 | 08:05 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Brad Penn 10w40.
Old Jun 28, 2015 | 08:39 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
Mobil1 15W50...has ZDDP additives for my flat tappet 350
Old Jun 28, 2015 | 09:08 AM
Red08's Avatar
Red08
Mobil 1 oil and filter
Old Jun 28, 2015 | 09:12 AM
Street Rat's Avatar
Street Rat
I thought I'd try Brad Penn 10w-30 in my fresh engine this go around.
Old Jun 28, 2015 | 09:39 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Shell Rotella 15W 40 and a Wix oil filter
Old Jun 28, 2015 | 09:49 AM
cagotzmann's Avatar
cagotzmann
Try the Amsoil Z-ROD 10/30. Your valve noise will be much quieter.
During startup and over all engine running.
ZDDP ratings are also very good.
Old Jun 28, 2015 | 09:55 AM
cagotzmann's Avatar
cagotzmann
Even my original L48 with 180k km ran smoother quieter with 10-30 Zrod than any other x/50 weight oils.
But I never did have any oil pressure issues.
I did try Mobil 1 15/50 when ZDDP oils were harder to find. Then I found the ZROD line with amsoil. went back to 10-30 for better startup protection. Flows much better for my colder climate area.
Old Jun 28, 2015 | 12:39 PM
CVO2FIXUP's Avatar
CVO2FIXUP
I was talking to the Amzoil rep, and he recommended the 20/50 Z rod for my BB. So I tried it. Seems very quiet on start up and general running. I am using the Valvoline Vr-1 20/50 in my Harley, seems to work well so far. Is this VR-1 the one you would use in the Vette?
And what is this Brad Penn oil? Never heard of it before. ?
Old Jun 28, 2015 | 01:40 PM
briankeery's Avatar
briankeery
Yep, that's it. I can only get that grade at my local NAPA, they can't get the 10W30........so to get the ZDDP, that's what I've got to work with. The 20W50 viscosity falls inside our summer temperature range in my owner's manual, car seems fine, motor's never been apart in 36 years.
Old Jun 28, 2015 | 02:30 PM
Sunstroked's Avatar
Sunstroked
Mobil1 10-30, wix filter. Roller cam installed.
To Motor oil survey.
Old Jun 28, 2015 | 03:19 PM
CVO2FIXUP's Avatar
CVO2FIXUP
You know what's crazy? Walmart sells this VR-1 20/50 here in Canada. I know, I was blown away as well. It's like $5 a quart.
Old Jun 28, 2015 | 04:31 PM
briankeery's Avatar
briankeery
Interesting, my small town SuperCentre has a moderately sized auto section; but I've never seen it there. Will have to check next time I'm there. I wonder why they won't transport the 10W30 across the border?
Old Jun 28, 2015 | 04:34 PM
Griff2002's Avatar
Griff2002
Originally Posted by zwede
Mobil1 0W-40.
