Changing transmission seals
Old Jun 28, 2015 | 05:59 AM
PBCloud's Avatar
PBCloud
Default Changing transmission seals
1970 454 auto.
Is this an easy job, and any tips/links welcome?
Paul
Old Jun 28, 2015 | 07:19 AM
diehrd's Avatar
diehrd
Which seals are you changing ?
Old Jun 29, 2015 | 01:22 AM
PBCloud's Avatar
PBCloud
All gaskets, and I assume front and back shaft seals.
Paul
Old Jun 29, 2015 | 07:23 AM
7T1vette's Avatar
7T1vette
If you have several areas of leakage, your tranny is probably very old and gaskets/seals are going bad. Also because of age, your INTERNAL seals and clutch plates are very worn.
If you want it done right, just pull the trans and have a reputable LOCAL trans shop rebuild YOUR transmission. Then it will be good for another 20+ years.
Old Jul 4, 2015 | 06:11 AM
PBCloud's Avatar
PBCloud
Thanks I was thinking in that direction.
Paul
Old Jul 8, 2015 | 07:13 AM
my 76 ray's Avatar
my 76 ray
First, I would try to determine WHERE it is leaking. If it is only the pan gasket, shifter shaft seal and/or dip stick o-ring then it might be possible to stop the leaks without pulling the transmission. I respectfully disagree with the opinion that your clutch plates are "very worn". That would depend on mileage and whether the tranny has ever been rebuilt. Internal seals would also depend on whether it has been rebuilt.
Old Jul 8, 2015 | 08:43 AM
7T1vette's Avatar
7T1vette
If the trans had been recently rebuilt, the external seals and gaskets would not be leaking....
Old Jul 8, 2015 | 06:14 PM
PBCloud's Avatar
PBCloud
Its only completed 60,000 miles and was working fine.
Paul
To Changing transmission seals
