1973 AC upgrade
Old Jul 1, 2015 | 09:17 AM
FM73project's Avatar
FM73project
Default 1973 AC upgrade
Rebuilding my 73 from the ground up. Any advice on upgrading the AC to be as efficient as possible, but still having the appearance of somewhat original. Thanks for any input.
Old Jul 1, 2015 | 10:40 AM
emccomas's Avatar
emccomas
Take a good hard look at the A/C systems that the retrofit companies use. Classic Auto Air, Vintage Air, Restomod Air.
Those systems are designed for efficiency, and for use in tight spaces.
I would consider replacing the entire 73 factor system with one of these kits.
Good luck with your car.
emccomas's Avatar
emccomas
I would consider replacing the entire 73 factory system with one of these kits.
Old Jul 1, 2015 | 02:28 PM
Afsooner02's Avatar
Afsooner02
Getting a vintage air done in my 73 as we speak.
Once done I'll let you know but have heard good things about it
Old Jul 1, 2015 | 03:34 PM
zwede's Avatar
zwede
On my '71 I switched to a Sanden compressor, a parallel flow condenser and R134a. It actually cooled too good, the evaporator would freeze up after a while. I added a temp switch from a late 70's pickup that turns the compressor off if the evap is close to freezing.
The Sanden is much smaller than the factory compressor and made it easy to get to the passenger side spark plugs.
Old Jul 2, 2015 | 07:48 AM
minitech's Avatar
minitech
It would be great to hear a report of how it went in and works from someone having it done.
Old Jul 2, 2015 | 04:58 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I did the same to my 77.
To 1973 AC upgrade
