Install Question for New Rear Shock Mount
Old Jul 12, 2015 | 07:44 PM
GregS_72's Avatar
GregS_72
From: St Louis MO http://1972corvetterestomod.blogspot.com/
Default Install Question for New Rear Shock Mount
Installing new rear lower shock mounts on my project and a quick question... does the rear shock mount get pressed into the spindle support so it sits flush? If so, how did you get it pressed in?
Thanks!
Greg
(strut rod left out of pic on purpose)
Old Jul 12, 2015 | 07:53 PM
jnb5101's Avatar
jnb5101
Use the nut to draw it flush. Use a larger nut or an end of a wrench as a spacer. But before you install it, coat the contact areas with anti-seize (copper grease) so that it can be removed in the future.
