ZZ4 Carburetor
Old Jul 13, 2015 | 01:12 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Default ZZ4 Carburetor
I have a ZZ4 in my '70 with headers and a TKO 500 trans and a 3.36 rear gear. I have an Edelbrock 1406 600 CFM carb on it now and am thinking or swapping it out for a Holley 770 that Jegs has listed for a ZZ4. Does anyone have experience with this carb? It's listed as GM Performance number 19212046 if that helps.
Thanks,
Jim
Old Jul 13, 2015 | 04:14 PM
MelWff's Avatar
MelWff
here's a test of the ZZ4 including that carburetor
http://www.hotrod.com/how-to/engine/...hevy-bolt-ons/
Old Jul 13, 2015 | 09:17 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Originally Posted by toobroketoretire
A 770 cfm carburetor is unnecessarily large for a 350" engine and unless it has vacuum secondaries it'll cause a big bog when used with an automatic transmission and a full throttle start. A 350" engine that is running with a 100% volumetric efficiency can only swallow 608 cfm at 6000 rpm so any carburetor that flows more than that is overkill. Street engines with automatic transmissions need vacuum or AVS type carburetors.
That carb has vacuum secondaries, and the OP doesn't even have an automatic transmission (TKO500 is a manual). Also, GM uses a very similar carb on their Turn Key version (Chevrolet Performance#809-19170093), but hey what do they know
Thanks,
Jim
I don't have any experience with that carb, but it should be fine. I run a 650 mech. secondary speed demon (it's wet flowed instead of dry flowed like Holley's - 8 to 16% different in rating scale) on my modified ZZ4, so say you subtract 15% from the 770cfm (dry) that equates to ~655cfm (wet).... so pretty close in size. I'm running a Richmond 5 speed that has close to the same 1st & 2nd gear ratios as your TKO500, but you have a steeper rear gear (3.36 vs. my 3.08). Even with a lightweight aluminum flywheel, I don't bog off the line or when I floor it as long as I have it in the proper gear (i.e. neglecting driver error). Just expect to do some tuning to it. No carb ever comes out of the box spot on.
Old Jul 13, 2015 | 10:26 PM
cagotzmann's Avatar
cagotzmann
Thanks,
Jim
Looks very similar to this
https://www.holley.com/products/fuel.../parts/0-80770
I found this to be a very picky carb. A lot of adjustments, from Power Valve, Vacuum Secondary Springs, Jets , accelerator pump Cam's etc. When you get a carb with this CFM size you need to make sure you don't have any vacuum leaks. I found this out chasing bogs on quick acceleration for weeks. I almost gave up. The smallest leaks caused low RPM bog problems. I also had the advantage of using my AFR data logger to help me see what is happening.
Do you have any baseline 1/4 mile speed or HP measurements so you can do a before and after.
Hopfully the change you are looking for can be measured. Are you looking for 1/4 mile speed; extra power ???
I am assuming you are not happy with the current performance.
Old Jul 13, 2015 | 11:40 PM
Raphiki's Avatar
Raphiki
No I'm not. The car stumbles on full acceleration like it's starving for fuel. It will recover but never seems to pull like it should. The carb I'm looking at is the one that comes with the turn-key engine so I'm hoping this will solve the problem.
Old Jul 14, 2015 | 12:23 AM
Sunstroked's Avatar
Sunstroked
Although I have a much larger edelbrock avs carb on my modified 383, I had to tune the carb. No matter what the carb manufacturer would like you to believe about out of the box ready to run.
In your case, if the carb is running well other than wot stumble, simply moving the pump link drive to a hole close to the carb body will increase the plunger stroke length, resulting in more fuel delivered.
I bought the jet kit. I had to go 2 stages leaner in the primary circuit and 1 stage leaner in the secondary circuit. The carb seems to perform very well.
The pump link change is free, a jet kit about $65. Either way, cheaper than another carb.
Old Jul 14, 2015 | 03:21 AM
Jason Staley
I have a ZZ4 in my '70 with headers and a TKO 500 trans and a 3.36 rear gear. I have an Edelbrock 1406 600 CFM carb on it now .....
Thanks,
Jim
Jim,
For what its worth, I use to run that exact carb on my ZZ4 years ago when it was unmodified. Even with adjusting the accelerator pump linkage and tuning the jets, rods, and springs I never could get the engine to respond well with that particular carb. I think Edelbrocks are great, but I never could get it tuned well on my ZZ4. Either I had low speed running (idle and cruise) dialed in with poor WOT, or vise versa. Never did figure out why that was, but eventually I ended up going the Holley type of carb. route.
Good luck,
Jason
Old Jul 14, 2015 | 07:43 AM
Raphiki's Avatar
Raphiki
Thanks. I'll try the pump linkage first but if that doesn't work I think it's new carb time.
Old Jul 16, 2015 | 07:46 AM
jersey68l36's Avatar
jersey68l36
Been using a Edelbrock Q-Jet on my slightly modified ZZ4 and it works great.
Old Jul 16, 2015 | 08:25 AM
Jason Staley
Could you provide more details such as cfm, jet & rod sizes, etc.? It might help the OP if you have this info readily available.
Old Jul 24, 2015 | 01:24 PM
Raphiki's Avatar
Raphiki
Decided to go with the Holley 770 and all I can say is DAMN! Had a few issues with the setup but once I got all the leaks plugged and the metal shavings out of the needle valve it really woke the engine up! Driving the car now is like an amusement park ride.
Old Jul 24, 2015 | 08:06 PM
loup68's Avatar
loup68
Army
I had bought a Holly 670 street avenger carb for my ZZ4 and I tried to get the bog out of it, when you floored it.
After trying all kinds of things, I finally gave up and bought a Holly spread bore. I had used one on my L-79 for over twenty five years and loved it.
The spread bore worked great right out of the box. You guys can keep the tinkering on your regular Holly carbs. Lou.
Old Jul 24, 2015 | 11:08 PM
Raphiki's Avatar
Raphiki
I had a bad bog with the Edelbrock 1406 but none with the Holley. Did you have vacuum secondaries or mechanical?
Old Jul 25, 2015 | 06:52 PM
loup68's Avatar
loup68
Army
My original spread bore has mechanical secondaries, but a manual (GM bi-metallic spring) choke . The new one has an electric choke and vacuum secondaries. Lou.
Old Jul 25, 2015 | 07:28 PM
Jason Staley
Glad things worked out for you.
To ZZ4 Carburetor
