Proportioning Valve Cleaning?
Old Jul 25, 2015 | 09:38 AM
cgarcer's Avatar
cgarcer
Default Proportioning Valve Cleaning?
Is there any cleaning procedure I should give to this part or make sure there is nothing built up inside it while I have it off? I will be replacing all of the lines. Car sat for a very long time. According to the service manual, it isn't serviceable.
Old Jul 25, 2015 | 11:15 AM
GregS_72's Avatar
GregS_72
From: St Louis MO http://1972corvetterestomod.blogspot.com/
might as well replace this too... I wouldn't risk reusing it personally
Old Jul 25, 2015 | 02:08 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Not knowing the year of car, but that does not look like a proportioning valve. Early C3s used these pressure differential switches to detect an imbalance between front and rear systems, then close a contact for the brake warning light. Works or it doesn't. Hardly a life safety issue.
Old Jul 25, 2015 | 02:17 PM
cgarcer's Avatar
cgarcer
It's a 77. Even it isn't a true proportioning valve, I didn't know if I needed to clean it some way.
Old Jul 25, 2015 | 03:25 PM
toddalin's Avatar
toddalin
Probably just regular flushing the brake lines is all the internal cleaning it ever needs.
Old Jul 25, 2015 | 09:10 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Block off the inlets/outlets to keep any foreign objects out during cleaning.
Take a soft brass toothbrush (firearm cleaning supplies) and some Brasso... Will clean right up.
I know the earlier switches are dated... Good reason to restore the original.
Regards,
Stan Falenski
To Proportioning Valve Cleaning?
