headers 454
Old Jul 19, 2015 | 05:04 PM
sportster89's Avatar
sportster89
Default headers 454
what header should I use short or long on my 74 with 454? A lot of conflicting answers out there. Thanks
Old Jul 20, 2015 | 03:02 AM
ajrothm's Avatar
ajrothm
For an under car exhaust system:
1) Hooker Super comps, 1 7/8"x3"
2) Hedman 2"x3".
Both fit relatively well and need minor mods to clear tall head bolts and around the idler arm.
Old Jul 20, 2015 | 11:20 AM
Les's Avatar
Les
2) Hedman 2"x3".
There's a video on Youtube using a high performance Chevy big block on a dyno to test exhaust components. The take away from that is- the shorty headers did almost nothing for the power curve. Long tube headers made a big difference. Adding an 18" collector extension to the long tubes added some additional horsepower and a bunch of torque.
My Hedmans required a small dimple on a tube on the passenger side to keep it from tapping the frame at idle. Other than that they fit perfectly.
Old Jul 21, 2015 | 03:00 AM
dugsgms74's Avatar
dugsgms74
Had a set of Hooker super comps 1 7/8" on my 68 427. Took them off and installed the factory manifolds w/ a gardner exhaust system. I feel the change cost me around 30-40 hp so headers definitely do help on a BBC. I do miss the power but its a #s matching BB car bound for NCRS judging so they had to go.
Old Jul 21, 2015 | 09:32 AM
sportster89
Default 454 headers
thanks for the info.
Old Jul 21, 2015 | 11:55 AM
ddawson's Avatar
ddawson
Too add to the other direction my 427 with too big a cam had factory manifolds.
Changed to Hedman headers and the difference was huge.
Old Jul 21, 2015 | 12:29 PM
sportster89
Default 454 headers
Did you use shot or long headers? Also how was your ground clearance?
Old Jul 22, 2015 | 10:09 AM
rajin cajin's Avatar
rajin cajin
Shorties are useless from everything I have read over the years.
Old Jul 22, 2015 | 10:26 AM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
When I had my '74, it had Hooker headers and side pipes. I would go that route again.
Old Jul 26, 2015 | 03:56 PM
sportster89
Default Headers 454
I was thinking that, but I just put on flow master mufflers that are open. I Really should go that route just for the cool look. Thanks
To headers 454
