TH400 transmission problem
Old Jul 23, 2015 | 12:24 AM
T-TOP TOM's Avatar
T-TOP TOM
Default TH400 transmission problem
My 74 has hasn't been run for 7 years now when I take it out it won't shift out of 1st gear. It was less than a quart low of fluid but even filled up it won't shift up. Any input on solving this problem will be greatly appreciated. Thanks, Tom
Old Jul 23, 2015 | 12:49 AM
dugsgms74's Avatar
dugsgms74
Check the vacuum line going to the vacuum modulator, if it falls off or has a leak in it you'll experience the problem you're describing.
Old Jul 23, 2015 | 03:35 PM
COOLTED's Avatar
COOLTED
I had a TH 400 do the same thing. The forward clutch was bad, got a total overhaul.
Old Jul 23, 2015 | 04:04 PM
1Fordman's Avatar
1Fordman
Take it out and run it up to a higher speed and if shifts 1-2 and 2-3 at higher speeds and with firm shifts, it's shifting by the governor. That confirms what the other poster said about the modulator. It could have a bad diaphragm, loose or kinked hose or be disconnected. If you pull the hose off and ATF oil is present the modulator is done.
Old Jul 24, 2015 | 02:32 PM
T-TOP TOM's Avatar
T-TOP TOM
Thanks to all who replied it turned out that the vacuum hose was disconnected at the intake manifold. This is what is great about this forum everyone is willing to help whenever someone is having a problem. Thanks again, Tom
To TH400 transmission problem
