1981 Spindle flange?
Old Aug 6, 2015 | 06:23 AM
Eric2vettes's Avatar
Eric2vettes
Default 1981 Spindle flange?
Is there a reason that none of the vendors list a spindle flange for an '81 automatic? I feel like my driver's side spindle to flange joint is worn and want to replace both components with new.
Old Aug 6, 2015 | 10:51 AM
MelWff's Avatar
MelWff
What is worn on the flange, only thing you could have is a groove where the seal rides?
Old Aug 6, 2015 | 12:57 PM
Eric2vettes
I'm getting a pinging noise in the wheel when the spindle gets loaded up. I think there might be some play in the splines. Could also be the U-joint or the bearings. I plan to just replace everything. Spindles are easy enough to find but a new flange isn't listed or available. I see what looks like the right part on ebay but for big money.
Old Aug 6, 2015 | 04:49 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
No one makes the yoke at this time. GM Discontinued them and there are not many used around to be sold. I looked on eBay too, looks like your guy got his part number wrong too. Funny, they were 74.25 in 1984 (below is copied from the old parts book)
80-81 Y W/AT.............. 14018209 2 74.25 YOKE. SPDL
Before you go buying one you might want to make sure yours is bad. We never sold or replaced many of these yokes and about the worst thing you would have is one with a groove cut in it from the seal and even that's pretty rare.
IMHO, I'd check the fit of the U-joint cap in the yoke to see if there is any play but your noise is probably the U-Joint.
Willcox
To 1981 Spindle flange?
