Bleeding brakes?
Old Aug 7, 2015 | 04:31 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Bleeding brakes?
It's been a while an honestly and I've forgot! I just finished the Borgesen steering box installation and need to bleed the brakes since the master had to come off in order to drop in the new box.
Do I bleed the passenger rear first then driver rear, passenger front, driver front?
Thanks!
Old Aug 7, 2015 | 04:45 PM
mortgageguy's Avatar
mortgageguy
That's the way I've always done it. Never had a problem. I've always bled the outer bleeder first on the rear.
Old Aug 7, 2015 | 05:54 PM
RS69's Avatar
RS69
I don't think it matters, but I started from the driver's front then the passenger side front, then passenger rear and the driver's side rear. It took a few tries, I replaced calipers and two of my new ones were bad. Lucky for me, I purchased locally and didn't take much time for replacements.
Old Aug 8, 2015 | 07:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Right rear inner
Right rear outer
Left rear inner
Left rear outer
Passenger front
Driver front
Works for me.
Old Aug 8, 2015 | 07:52 AM
AdamMeh's Avatar
AdamMeh
All I know is, a friend who did mine owned a brake shop for over 20 years and told me to start with the wheel farthest from the master cylinder and work to the closest (drivers front).
Adam
Old Aug 8, 2015 | 09:27 AM
diehrd's Avatar
diehrd
Easiest way by your self... Open the rear bleeders on both sides , Get beer ,, make sure master cylinder has cap off and stays full , , let it gravity bleed.
Do same for front ..
You will be looking for a steady stream to be running out of the bleeders.
Old Aug 8, 2015 | 09:56 AM
fotyfobravo
Thanks folks!
Old Aug 8, 2015 | 12:09 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
That's how I've always done it and never had a problem. Just be sure to keep the mc level up as mentioned.
Old Aug 8, 2015 | 12:42 PM
AdamMeh's Avatar
AdamMeh
You will never get all of the air out of a brake system by using gravity, and no legitimate brake shop that does that. Why? Because it's not effective, or safe.
Old Aug 8, 2015 | 05:41 PM
diehrd's Avatar
diehrd
Non sense . I have 4 corner racing breaks from Aero space components and did it as I described ..
Tell me my car has a bad pedal and is unsafe ..
Old Aug 8, 2015 | 06:07 PM
AdamMeh's Avatar
AdamMeh
Because you did it doesn't make it right.
Old Aug 8, 2015 | 07:56 PM
diehrd's Avatar
diehrd
First of all bleeding breaks can be done a few ways , one is gravity , one is wheel by wheel with someone pumping them up and another is with a power bleeder.
Start video if you want at 3:50 into clip
I am sure this is a coincidence him doing it to a corvette however it clearly demonstrates gravity bleeding ..Your welcome AdamMeh for me showing you something you can use in the future.
Old Aug 8, 2015 | 08:00 PM
AdamMeh's Avatar
AdamMeh
And you respond with sarcasm. How typical for you.
Back to the block list with you!
Old Aug 8, 2015 | 08:02 PM
diehrd's Avatar
diehrd
How you take it that way is funny .. However you do agree you are wrong and gravity bleeding is a safe effective way to bleed brakes and I thank you for your acknowledgement your a stand up guy for sure to admit you are wrong..
To Bleeding brakes?
