Overheating 454
Old Aug 10, 2015 | 10:43 AM
genep's Avatar
genep
Default Overheating 454
Can someone help, I have a 454 new rebuilt motor in a 1978 corvette, new 3 core aluminum radiator with 2 12 " fans, new water pump , 160degree thermostat , motor runs at 200 degrees when hot ,does not fill the overflow tank, how can I test to see if something is blocked.
also upper radiator hose seems to swell,
Old Aug 10, 2015 | 10:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
200-220 is normal operating temperature.
Old Aug 10, 2015 | 11:02 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Is the rad full when cold? If not, water expansion may not reach the overflow tank. Re the 160 stat, be aware that running this low temp stat will create condensation problems in the oil and exhaust system if the engine is not brought up to operating temp which takes longer than with a 180 or 195.
Old Aug 10, 2015 | 11:15 AM
JimLentz's Avatar
JimLentz
Is that temp in stop and go, highway driving, or both?
Old Aug 10, 2015 | 11:52 AM
qwank's Avatar
qwank
a 160 degree thermostat does not mean it will run at 160. 200 is normal. i'd say you're doing fine.
Old Aug 10, 2015 | 12:06 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie question: Is it possible from what I've read that the 160* thermostat allows the coolant to circulate too fast (similar to central A/C unit in a home where a "high rpm" forced air fan pushes air past the cooling coils too fast for the air to reach it's coolest temperature)----the engine coolant does not have time to release enough heat?
Old Aug 10, 2015 | 12:18 PM
Wee's Avatar
Wee
Double check that the gauge is reading correctly....My 72 read between 210-230 on my initial drive home, so I installed another temp gauge that I tested and while the original gauge read around 215 actual temp was around 190 on the new gauge.
Brian
Old Aug 10, 2015 | 12:34 PM
genep's Avatar
genep
Havent really had it on the road to long but it seems very hot the temp gauge climbs towards 220, I have discs on the back of the heads that popped ,the engine builder put them there to warn of overheat and they popped
Old Aug 10, 2015 | 12:35 PM
genep's Avatar
genep
I was told by a well known mechanic that 454s run better at the 160 therostat
Old Aug 10, 2015 | 12:36 PM
genep's Avatar
genep
Rad is full when cold
Old Aug 10, 2015 | 12:44 PM
Jud Chapin's Avatar
Jud Chapin
I'm afraid that's BS. Whatever stat is used, the engine will eventually reach its normal operating temp (as long as it's not rated at a higher temp). Some are of the incorrect opinion that the temp of the stat is where the engine will operate. The stat temp only tells you at what temp it will open allowing passage of coolant.
Old Aug 10, 2015 | 12:48 PM
Jud Chapin's Avatar
Jud Chapin
Then where does the additional coolant from expansion go if not to the overflow tank? Makes no sense to me. Maybe others have an explanation.
Old Aug 10, 2015 | 12:57 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
my 500hp 454 runs at 165 degrees, 160 T-stat with a stock cleaned Radiator.
if your temperature is more than 20 degrees above your thermostat,
you may an issue. I think you still have air in your system.
it can be difficult to remove air in a corvette.
Old Aug 10, 2015 | 01:45 PM
genep's Avatar
genep
any ideas on how to do that
Old Aug 10, 2015 | 02:34 PM
steffan's Avatar
steffan
I don't have a 454 but A 427.the overflow tank is where you check the coolant leval.
Their is no cap on the radiator.the overflow tank should have coolant in it.car runs at about 210 city.add collant to the overflow tank if needed,with the cap off the overflow tank warm up the car.rev the gas high.it should gulp in the needed coolant.any extra coolant should come out the overfill tube.
Old Aug 10, 2015 | 03:33 PM
69Vett's Avatar
69Vett
Air-Lock there are several ways to address, the problem is the engine sits higher than the radiator if you trap air in the engine, it profits heat transfer to the water, I personally fill my system via holding the top radiator hose-up and pouring in until it comes out your overflow or radiator.
upon installing a new 454 motor I had the same initial problems it would continue to heat up to 220 or so, to hot for me, I add to refill my system like 3-4 times,
once I got it right, the temperatures would raise to 165, and sit there solid and no longer continue to increase temperature.
Old Aug 10, 2015 | 07:19 PM
LS4 PILOT's Avatar
LS4 PILOT
To maximize cooling at moderate speeds .....GM put a lot of cut shapedfoam pieces around the shrould to help force the air though the radiator . ......moving your car should drop temp from T stat range , not increase . My car idles on a 90 degree day sitting still 195 -200. .....but once I'm moving it will drop back to 180 190 range and that's on a HOT azz day . 200 is ok long as it backs down once your under way.....as air flow is induced.
THere was a special spoiler extension used on LS4 73 -74 with AC .....5 inch or so stiff rubber dam was riveted to the small plastic lip to help force air up though the lower cooling slots .
It does make a nice difference at speed. Very difficult to find factory piece. But you might make one up.
Also my car came with a big 7 blade fan and fan clutch . These work well too ......I replaced my fan clutch 20 years ago .....still all good.
To Overheating 454
