Power steering to manual steering
My '68 project has the original MANUAL STEERING BOX......it feels better than power steering.....
UNTIL YOU DECIDE TO PARALLEL PARK....THEN YOU GET A GOOD WORKOUT!
Other than that, I like it (but I'm getting rid of the 13" diameter steering wheel the previous owner installed....and going to a 15" steering wheel for better parking leverage!)
Do what this man says, you won't look back.....
Regards from Down Under.
aussiejohn
but everything will be out and that is the time to do it.
In case you weren't already aware, the '79 steering arms only have the "quick" ratio holes drilled for power steering, which will require ~15% more effort than would having the outer tie rod ends in the manual steering location. I've driven manual steer C3s in both settings, and IMHO there is a noticeable difference, but I kinda like quick-manual for spirited driving. If you should decide you want the manual setting, better to just install earlier steering arms, as the correct tapering bit costs nearly as much and requires precision work x2 to get them right.
FYI, power steering setups aside, with manual steering you won't likely need/desire more than 2-3* pos caster. Less caster won't be as stable, which could be disconcerting initially, while more than necessary can make steering unnecessarily heavy. Once you get fairly used to it you can fine tune it to adjust feel to your liking. My $.02, HTH.
TSW
If you want to make the swap, all you need is the pitman arm and center link, pictured in redvetracr's post above. Also, I agree with TheSkunkWorks about the 79 steering arms only having one setting, and because of this, the resulting increased effort that will be needed to steer the car without power assist.
Another thing to consider is how wide the tires you plan to run are, and do you have air? A 50 or 60 series tire, will take added effort to steer, and the extra weight of an AC system, will also increase the effort needed.
I've had cars with and without steering. It's not a big enough issue to me, that I'd add it to a car that didn't have power steering, but I don't think I'd ever remove it from a car that came with it.
The factory power steering is not acceptable by today's standards. I have absolutely no road back feel with my factory PS steering. Parking the car in a parking lot, or driving around a high speed corner, I have no feedback at all...it feels like I'm operating the steering wheel with the front wheels up on jacks.
On a high speed corner, I can feel my 08 steering wheel forcing me to maintain a steering turn. On a high G turn, the 08 gives a strong pressure to maintain the turn....not the 68.
I thought the c2 and c3 were basically the same frame and suspension so how is this?
I considered going non power steering but it has too mnay cons,
"parking isnt that bad"
I am running a bb and wide front tires and will have my wife driving a lot, for me to remove the PS would really be a down grade...
