Foam Collar
Old Aug 17, 2015 | 11:33 AM
Droop's Avatar
Droop
Default Foam Collar
Good morning everyone. Does anybody know if GM used a heat insulating foam collar around the automatic transmission of a 1970 Corvette. I know they used it on the standard version. Thanks Droop. P.S. My AIM manual does not show it of an automatic.. Thanks Droop
Old Aug 17, 2015 | 11:54 AM
Alan 71's Avatar
Alan 71
Hi D,
Yes, all cars received the 'foam collar'.
Regards,
Alan
You can see it in place on this 69 M40 body drop picture.
More clearly seen in this picture of a 4-speed car.
Old Aug 17, 2015 | 03:58 PM
gbvette62's Avatar
gbvette62
All 68-79 Corvettes got the foam transmission collar.
Old Aug 18, 2015 | 08:46 AM
Droop's Avatar
Droop
Thanks, Alan and GB. Alan a couple of questions. Where did you get those wonderful photos? On your 1971 Corvette can you give me a little of the history. The reason I ask, this is for restoration of my 1970 Corvette. Yours looks Original in every way. My paint is factory with all it imperfections GM put in it. Trying to decide what to do with the Body Paint. Droop
Old Aug 18, 2015 | 09:47 AM
AdamMeh's Avatar
AdamMeh
Is is possible to install this collar without pulling the trans?
Great info as usual Alan!
Adam
Old Aug 18, 2015 | 10:35 AM
DonnieP73's Avatar
DonnieP73
Adam
Yes it is. I put a new one in my 73 after I had installed the motor
and transmission back in. It fits so tight that I didn't need anything
to glue or fasten it in.
Donnie
Old Aug 18, 2015 | 11:39 AM
ddawson's Avatar
ddawson
If you remove the trans mount you can let the tail drop enough to push it up in place.
Old Aug 18, 2015 | 11:40 AM
Alan 71's Avatar
Alan 71
Hi D,
The first picture has appeared many places. I believe I copied it from Bizzoco's 1969 Stingray guide Book.
The second picture is from the 71 introduction issue of Corvette News (Oct.-Nov.1970).
As far as my car is concerned I'm the original owner. It has about 46k miles on it. I started the restoration in 1994 and finished it about 2007.
My original intent was to restore it to how it was when I was driving it in 1971 and 1972, but in 2010 I decided to re-do some things in anticipation of having it Flight Judged in 2011 for it's 40th birthday.
I continue to re-fine it now in anticipation of having it Flight Judged again in 2021 for it's 50th birthday…. if I live that long.
As far as what to do about the paint on your car perhaps you should ask 7T1 about it since he seems to be pretty knowledgeable about restoration issues.
Regards,
Alan
Old Aug 18, 2015 | 11:43 AM
AdamMeh's Avatar
AdamMeh
Thank you for the responses guys! This is now on my to-do list.
Old Aug 18, 2015 | 02:32 PM
Droop's Avatar
Droop
Originally Posted by Alan 71
Hi D,
Regards,
Alan
Alan, See if 7T1 chimes in on the paint issue. I'm going to put the body back on first then the Collar. That makes sense to me. The reason is, I couldn't find the spec that tells you the measurement down the bell housing where the collar goes on. Alan you will make it. Just keep moving and enjoying the things you love. Droop
Old Aug 18, 2015 | 06:14 PM
John 65's Avatar
John 65
Great pics as always Alan.
Going to pick one up in Carlisle in a few weeks.
Just to see if it would actually make a difference, I temporarily put some pipe insulation in there not to long ago and I was surprised it really did help.
Old Aug 18, 2015 | 06:54 PM
Alan 71's Avatar
Alan 71
Hi John,
I think it's another one of those things that IF it had no effect on interior heat Chevrolet wouldn't have spent the 25 cents it cost per car.
Regards,
Alan
Old Aug 18, 2015 | 09:15 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Alan,
I love the drop body pic for the 69.
I would love to blow that up and have it on the garage wall.
Droop,
My collar is long gone too.
I think whoever replaced the clutch last just ripped it out and discarded it. They obviously didn't think it was needed. It's on the list too. The best cars I think are the one's like Alan's where they were loved from delivery. Owner after Owner they kinda digress from there.
Marshal
Old Aug 19, 2015 | 07:12 AM
Alan 71's Avatar
Alan 71
Hi Marshal,
Yes, those are 2 terrific pictures.
Imagine how many questions could be answered if someone with a digital camera had had about 15 minutes to walk around those bodies and chassis' and take pictures!!!!!!!!!!
Regards,
Alan
Old Aug 19, 2015 | 05:58 PM
Droop's Avatar
Droop
Hi Marshal,
Regards,
Alan
Alan and Marshal, Before I put the body back on my 1970 I'll us my wife's I phone or someones digital camera and do a walk around. I have a bunch of photos before the restore that I will post on a URL. I will share it with the forum. Hopefully in about 2 or 3 months. Marshal, There was nothing left of my collar except a spot of glue on the top of the transmission. Droop
Old Aug 20, 2015 | 10:18 PM
68/70Vette's Avatar
68/70Vette
An adjunct to the horseshoe insulation....for the 1968 and 1969 cars, GM provided standard insulation for the under half of the engine firewall and also under the driver's and passenger's side under floor pan. A steel sheet metal protection was provided for this under floor pan insulation and protection. This extensive insulation system for the 68 and 69 Corvettes can be still bought...Paragon Vettes for one. It's very inexpensive and if you have a 70 and above Corvette, I think you should consider installing it. I've installed it on my 70. It's bewildering that GM abandoned this insulation system for the cars after 69.
Old Aug 21, 2015 | 03:17 PM
Droop's Avatar
Droop
68, I'm going to look into that package. Thanks Droop
To Foam Collar
