U Joint Question
Old Aug 18, 2015 | 09:42 PM
hzz's Avatar
hzz
Default U Joint Question
For a 1971 big block, 4 speed, is the correct u joint for the drive shaft a Spicer 5-1330-1X?
I think that's correct, just want to make sure.
Old Aug 19, 2015 | 12:18 AM
Solid LT1's Avatar
Solid LT1
Yes the 1330 Ujoint is the proper one for a 71 driveshaft unless someone has installed parts for a different year. You should consider Spicer HD Ujoints for you torquey big block.
Old Aug 19, 2015 | 07:04 PM
DUB's Avatar
DUB
FOR What it is worth.
I AGREE with Solid LT1.
Get SPICER U-JOINTS that DO NOT have a grease fitting in it. You might 'think' that using a U-joint with a grease fitting is better....but in your case.....Big Block and 4 speed.....you actually would be better off with a solid U-joint hat HAS NO grease fitting in it...and they will last a very long time....depending on how much abuse you put the car through. NO Corvette left the plant with a U-joint in it that had a grease fitting in it that I am aware of. And using the argument that you want to be able to grease the U-joint and make them last...just does not 'fly' with me because I have replaced countless U-joints with the solid design...and they last a LONG time. The last set I replaced lasted 70,000 miles on street driver....which is why I give 5 year/50,000 guarantee to the Spicers I put in (excluding drag strip applications). And I wish I had a photo of cars that I have had to repair that the half shaft U-joint broke and damaged the underbody. SO...if getting new U-joints....do yourself a favor and get the Heavy Duty ones with NO grease fitting.....or don't....it is your car and do as you wish.
DUB
Old Aug 19, 2015 | 10:10 PM
hzz's Avatar
hzz
Thanks for the advice.
Spicer u joints with no grease fitting it is
To U Joint Question
