Pulls to the right?
Old Aug 21, 2015 | 07:33 PM
Oldriceguy's Avatar
Oldriceguy
Default Pulls to the right?
I've had my 77 for about a month now and am working out minor things, but the car pulls hard to the right. I had it in an alignment shop today and they were unable to fix it. They got adjustments to the computer specs. It does have power steering. Tire air pressures were checked. Any thoughts?
Old Aug 21, 2015 | 07:49 PM
Roughrider's Avatar
Roughrider
You could have a bad tire...tread separation or something else. That can cause pulling. Swap the front tires and see if it's the same or pulls the opposite way.
Also...you might have a brake hose collapsing internally...not uncommon on these cars after so long. The brake caliper might not be fully releasing. If you don't know how long since the hoses were last changed...if ever...it would be prudent to go ahead and have it done and the brake system fully checked.
Old Aug 21, 2015 | 07:52 PM
sportster89's Avatar
sportster89
Default pulls right
I found my 74 brake calipers were hanging up,when i would brake car would pull.I changed the calipers and it fixed my problem. good luck
Old Aug 21, 2015 | 08:26 PM
Brcmpbl's Avatar
Brcmpbl
#1: Check your brake hoses. They can look perfect from the outside but be in bad shape on the inside.
Old Aug 21, 2015 | 08:40 PM
'75's Avatar
'75
Check and re-center the power steering control valve, out of adjustment and it will pull to one side.
Old Aug 21, 2015 | 08:58 PM
Oldriceguy's Avatar
Oldriceguy
I had the tires rotated and checked for a dragging brake.
Old Aug 21, 2015 | 09:01 PM
Oldriceguy's Avatar
Oldriceguy
You might be on to something here. I suggested to alignment guy that it feels like power assist cylinder is pushing to one side after the tire rotation and brake check. Gotta try that tomorrow. Thanks!
Old Aug 21, 2015 | 09:23 PM
toobroketoretire's Avatar
toobroketoretire
Okay, here's how I go about adjusting my power steering control valve:
1. Remove the dust cap from the end of the valve.
2. Gather up a 1/4" drive ratchet, a 6" extension, and a 7/16" socket.
3. Drive it on the crown of a straight road and see how it steers. If it pulls to the right pull to the shoulder of the road, turn your wheels all the way to the right, then turn the 1/4" NF adjustment nut about 1/8 turn CLOCKWISE.
4. Keep adjusting that 1/4" NF nut in 1/8" increments until it steers dead straight with your hands off the steering wheel.
5. Re-install the dust cap and you're done.
Old Aug 21, 2015 | 09:34 PM
Oldriceguy's Avatar
Oldriceguy
I'll give that a try. Thanks
Old Aug 21, 2015 | 09:44 PM
'75's Avatar
'75
Not a good idea, you could be over-adjusting the valve to cover up another problem.
Correct way is to jack up and block the car. Disconnect the rod end of the assist cylinder. Start the engine and see if the cylinder extends or retracts by itself. Remove the dust cap from the valve, turn the adjustment one direction till the rod just begins to move, turn the adjustment back the other way while counting the number of turns till the rod just begins to move the opposite direction. Turn the adjustment back half the number of turns you noted and it should be centered. Reattach the rod to the anchor point and test drive.
Old Aug 21, 2015 | 09:48 PM
sstopczy's Avatar
sstopczy
Okay, here's how I go about adjusting my power steering control valve: 1. Remove the dust cap from the end of the valve. 2. Gather up a 1/4" drive ratchet, a 6" extension, and a 7/16" socket. 3. Drive it on the crown of a straight road and see how it steers. If it pulls to the right pull to the shoulder of the road, turn your wheels all the way to the right, then turn the 1/4" NF adjustment nut about 1/8 turn CLOCKWISE. 4. Keep adjusting that 1/4" NF nut in 1/8" increments until it steers dead straight with your hands off the steering wheel. 5. Re-install the dust cap and you're done.
The proper way to center it is to disconnect it from the frame and center it using the adjustment but. Detailed instructions can be found in the service manual.
Old Aug 22, 2015 | 10:31 AM
Oldriceguy's Avatar
Oldriceguy
I watched the C&S Corvette video yesterday on replacing the power steering control valve. Good video. I'm going to jack it up, remove tire and disconnect the assist rod from the frame and adjust it there.
Thanks Everyone.
Old Aug 22, 2015 | 12:47 PM
Dr-G's Avatar
Dr-G
Power steering assist was what I was first thinking too because I just replaced mine this past week. The instructions that came with it sucked.
I found the "How-to" on Willcox's website and it was more clear, however, mine was still not quite right and was hard to turn to the right after adjustment so we had to tweak it a bit to even it out. Seems like the adjusting nut is very sensitive, just a slight turn makes a difference.
Old Aug 22, 2015 | 01:18 PM
REELAV8R's Avatar
REELAV8R
Yes this is the correct way to do it.
Do it this way if you need to waste an afternoon or several, since it probably will need re-adjusting several time to get it right.
Old Aug 22, 2015 | 03:40 PM
toobroketoretire
After re-sealing a control valve the initial adjustment CAN be done by disconnecting the rod and centering the valve but the final adjustment still needs to be made under actual driving conditions because there are dynamic forces involved when driving down the road. So what are these "dynamic" forces?
1. The pump is spinning a lot faster and pumping a greater volume of oil.
2. The frictional drag of the tires on the road causes the linkage to push/pull on the control valve ball stud which pushes and pulls on the control valve spool.
3. As the oil gets heated it thins which causes a change in the amount of force pushing against the control valve spool.
I've been making these roadside adjustments all the way back to the 1955 Chevrolets because they used the exact same system. In fact many 18 wheelers use the same system only much larger like 3' diameter cylinders and larger pumps.
Old Aug 22, 2015 | 04:05 PM
Dr-G's Avatar
Dr-G
After re-sealing a control valve the initial adjustment CAN be done by disconnecting the rod and centering the valve but the final adjustment still needs to be made under actual driving conditions.
This is what happened to me. We had it adjusted perfect then when we put it on the ground it was still hard to turn right. We tweaked it with the rod attached on the floor. Steers straight and does not pull at all now, plus, no more wandering.
Old Aug 22, 2015 | 04:13 PM
REELAV8R's Avatar
REELAV8R
Might want to try it the easy way next time. Worked perfect for me. I didn't have to drive it to get it centered dead on.
Maybe if you have loose or worn components or too much frame flex, or your alignment is poor, you get pull and you're adjusting the power steering to compensate for one or more of those factors.
To Pulls to the right?
Old Aug 23, 2015 | 09:01 AM
toobroketoretire
Hey, that's good to know..................
Old Aug 23, 2015 | 09:20 AM
toobroketoretire
Default Dynamic Forces Change Everything
The "easy" method is great for the initial adjustment but dynamic forces change once the car gets underway. As the piston area on the left side of the cylinder is considerably less than the right side the amount of hydraulic force available on the left side is considerably less and that's why it takes less effort to turn to the right than to turn to the left (you did know that, didn't you?).
Old Aug 23, 2015 | 10:27 AM
'75's Avatar
'75
A correct alignment is what keeps the car going straight. If you need to correct your alignment by tweaking the control valve, time to get the alignment right. It's a power assist, not an alignment corrector. Power steering fluid overheat could be a result.
